![]() | Home > In Car Electronics > Fitting tweeters - TD5 |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4794 ![]() ![]() ![]() |
They're 130mm edge components. Just cheap ones from halfords but they don't sound too bad. Eventually I'll do a full blown focal setup ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5882 ![]() ![]() ![]() |
If I did decide to fit speakers in the lower part of the dash what size holes would need to be cut? 1999 Defender TD5 110
I fitted Focal tweeters,in the same place as Pumas.Think I used a 40mm hole saw for an absolute perfect fit,didn't need mastic or anything!!
Also fitted 5 1/4 inch (130mm) speakers in place of the originals (4 inch,100mm),only needed to slightly widen the original holes,(+25mm mdf speaker rings).Trim the thin foam and easily snip the 1mm metal backing with cheapo wire cutters/tin snips. Pov.spec,ftw. 2006, 110,TD5. |
Thanks JimBob7. For those Defenders without speakers (Poverty spec?) do the dashboards come marked where the speakers need to go? I.e is there a moulding mark somewhere? 1999 Defender TD5 110
No Td5s had tweeters on top of the dash and there are no marks to tell you where to put them, I just spaced them equally from each end so they looked OK. Ray
Djcla Member Since: 29 Jul 2017 Location: Gloucestershire Posts: 469 ![]() ![]() |
im interested in doing this but a little confused as to how you wire the tweeters up to a head unit can anyone explain?
Puma tweeters with crossovers built in wired in parallel with main speakers
Ah ok so you basically piggy back onto the main speaker connection or join the wires together?
Yes + to + and - to -
They sound good what were they make/model wise? |
