Home > In Car Electronics > Heated seat not working but dies when swapped around?
Retrostu
United Kingdom 2005 Defender 90 Td5 XS CSW Java Black
my TD5 heated seats have a problem my drivers side not working but passenger does nicely, both base and back,
Swapped the seat bases round and drivers base does work/heats, when plugged into passenger side then tried passenger base plugged into the drivers side plugs into and not working, what gets priority though, back part then base or both powered simultaneously?
Post #504288 13th Feb 2016 2:24pm
PaulMc
The seat base and back are wired in series - so, it sounds as though your driver's seat back has failed open-circuit.
. Paul.
Post #504298 13th Feb 2016 3:11pm
dorsetsmith
Post #504304 13th Feb 2016 3:31pm
Retrostu
Oh great! Thanks for that I really appreciate it, is it possible to take the back cover off to take a look or will it be a tiny wire linking element together?
Post #504305 13th Feb 2016 3:33pm
Retrostu
dorsetsmith wrote:
http://www.ebay.co.uk/itm/Genuine-Land-Rover-Defender-front-outer-seat-back-heater-pad-no-plugs-90-110-XS-/231666479540?hash=item35f065f1b4:g:jY0AAOSw0JpV3XyH
this might be interest
Oh nice one I might get wiring checked Monday, if not can I fit that easily or is the cover a real pain to get of and refit correctly?
Post #504306 13th Feb 2016 3:37pm
ickle
Trim is a doddle - I use small zip ties to refit - I think there's a video on Exmoor trim / Youtube
Post #504311 13th Feb 2016 4:16pm
dorsetsmith
exemor trim seat re trim
Post #504312 13th Feb 2016 4:22pm
Retrostu
Well found a yellow wire loose on the back heated pad, tried to solder back onto what looks like a small magnet with two terminals but don't know if this is correct, unfortunately it has not worked unless I have not soldered it correctly
Post #504318 13th Feb 2016 4:35pm
Retrostu
Deleted
Deleted
Post #504319 13th Feb 2016 4:37pm
dorsetsmith
do you have multimeter to check cct courtney
Post #504320 13th Feb 2016 4:40pm
Retrostu
No I don't unfortunately
Post #504321 13th Feb 2016 4:42pm
Martin
Site Admin
That's the failure I had on one of the seats I put in my soft top, soldering a small extension wire to the thermal switch (silver circle thing) and to the broken yellow wire completed the circuit again.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #504417 13th Feb 2016 10:06pm
Martin
Site Admin
Got a close up of your current wiring/soldering?
Have to say even a cheap £5 meter is absolutely invaluable when doing electrical work.
Should be in every tool box IMO Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #504420 13th Feb 2016 10:08pm
dorsetsmith
+1
Post #504481 14th Feb 2016 8:08am
Retrostu
Well I double checked my soldering and still attached but I took it back off and connected a spade connector instead, still no joy though unfortunately so luckily found a new genuine rear heat pad on fleabay for £28 posted so I'll take a punt on that and see how I get on, only thing is its minus the connector but I can just use the one off of the broken one, so hopefully it will be sorted and warmer!.
I'll keep you posted.
Thanks for the advice too
Post #505721 18th Feb 2016 7:24am
