![]() | Home > In Car Electronics > Heated seat not working but dies when swapped around? |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 504 ![]() ![]() ![]() |
The seat base and back are wired in series - so, it sounds as though your driver's seat back has failed open-circuit.
. Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
http://www.ebay.co.uk/itm/Genuine-Land-Rov...Sw0JpV3XyH
this might be interest |
Retrostu Member Since: 03 Feb 2016 Location: Kent (AKA Garden of England) Posts: 128 ![]() ![]() ![]() |
Oh great! Thanks for that I really appreciate it, is it possible to take the back cover off to take a look or will it be a tiny wire linking element together?
Oh nice one I might get wiring checked Monday, if not can I fit that easily or is the cover a real pain to get of and refit correctly? |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1811 ![]() ![]() ![]() |
Trim is a doddle - I use small zip ties to refit - I think there's a video on Exmoor trim / Youtube
exemor trim seat re trim
![]() Click image to enlarge Well found a yellow wire loose on the back heated pad, tried to solder back onto what looks like a small magnet with two terminals but don't know if this is correct, unfortunately it has not worked unless I have not soldered it correctly |
Deleted
do you have multimeter to check cct courtney
No I don't unfortunately
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6635 ![]() ![]() ![]() |
That's the failure I had on one of the seats I put in my soft top, soldering a small extension wire to the thermal switch (silver circle thing) and to the broken yellow wire completed the circuit again.
Got a close up of your current wiring/soldering?
Have to say even a cheap £5 meter is absolutely invaluable when doing electrical work. Should be in every tool box IMO ![]() ![]() ![]() |
+1
Well I double checked my soldering and still attached but I took it back off and connected a spade connector instead, still no joy though unfortunately so luckily found a new genuine rear heat pad on fleabay for £28 posted so I'll take a punt on that and see how I get on, only thing is its minus the connector but I can just use the one off of the broken one, so hopefully it will be sorted and warmer!.
I'll keep you posted. Thanks for the advice too |
