Home > Maintenance & Modifications > cross member bolts easy to swap?
Page 1 of 3 123>
Stacey007
Hello
I've noticed my rear cross member needs a tidy up and may have a go at spraying this once some better weather... and changing the bolts in the picture. Are these easy to change (for stainless ones)
Thanks
Smile
Post #498851 31st Jan 2016 9:49pm
mikeh501
Yes, peice of cake.
Post #498877 31st Jan 2016 10:26pm
miker
Very easy although I personally wouldn't. Stainless will react more (and thus corrode) the aluminium tub more readily.
I would stick with some decent BZP bolts and either paint over them, or keep them in good condition with semi-regular use of ACF-50 or similar.
If you do decide to go down the stainless route, not that standard grade stainless bolts shouldn't be used for structural bits, I believe A4-80 is equivalent to an 8.8 bolts. I tend to over-engineer, but I have used at least BZP 8.8 on all my body tabs, and then 10.9 on all my towing equipment.
Whatever you go for, give everything a generous glob of anti seize paste such as duralac. This is even more important for stainless!
Post #498910 1st Feb 2016 12:02am
leeds
The Nakatanenga bolt kits we supply come with lubricant/anti seize paste as standard Thumbs Up
The bolts will be A2-70 these are corrosion resistant with a minimum tensile stress of 700 N/mm2. A4 is corrosion resistant in a more chemically harsh regime I.e. Marine grade then A2 which is corrosion resistant under fresh water regime.
Yes stainless steel is wider apart from aluminium then mild steel and aluminium in the galvanic tables. Have never looked at where zinc is in these tables in comparison to aluminium. However those tables will not take not consideration the effect of paint etc.
IF, and I repeat IF you are seriously worried about corrosion then maybe using a Defender in its natural environment is not for you. There are lots of mud traps on the chassis, which can collect road salt etc which will cause corrosion. The doors are aluminium on a steel frame, has all the steel swarf been clean out? Foam rubber used in the door structure also cause corrosion issues.
Plastic washers can be used under the stainless washer if so desired. For the rear cross member a good coat of paint and the inside given a good coating of waxoyl/dinitrol etc would be more important as it has lots of mud catching crevices.
Brendan
Post #498915 1st Feb 2016 2:11am
ericvv
Post #498916 1st Feb 2016 2:53am
Stacey007
Hi Brendan
do you have a link for the kit I need just to do the cross member?
I on;y found these which looks like it would cover the complete car... Smile
http://www.4x4overlander.com/product/nakat...ast-110ht/
Thanks
Post #498985 1st Feb 2016 9:33am
leeds
Please email info@4x4overlander.com with your exact requirements.
We do not have a rear cross member kit as such but I have various loose bolts on our shelves so I will see what I can do. No promises however
Brendan
Post #499390 1st Feb 2016 10:55pm
nitram17
Re: cross member bolts easy to swap?
Stacey007 wrote:
Hello
Thanks
Smile
Try these stacey good product good company!
http://www.yrm-metal-solutions.co.uk/epage...ucts/1028A
good source of defender Bits and Pieces!
Post #499393 1st Feb 2016 11:01pm
miker
Brendan
True. They rust and corrode, always have done, always will do. I just prefer to do the things within my power to make the process as slow as possible! Same reason I keep it reasonably clean and the chassis will be dinitrolled come summer.
I stand by using only 10.9 Bolts on the structural/towing bits though!
Post #499409 2nd Feb 2016 12:54am
Screbble
Stacey007 wrote:
Hello
Thanks
Smile
Go for it Stacey007 Thumbs Up
Plenty of stainless steel bolts available via suppliers already referenced above and on eBay.
Again as mentioned, I've used Duralac and plastic washers. Overkill but I'm an Anorak Rolling with laughter
Costs very little but makes a difference to me anyway Thumbs Up
Might be worth getting some penetrating oil on them before you get stuck in. You can get to the threads on some of them from underneath.
Best of luck.
Post #499768 2nd Feb 2016 11:57pm
I've got the Nak SS kit from Brendan.
It's excellent. Thumbs Up
Also agree on the 10.9 on towing bolts etc, they are easily swapped anyway.
Just stick to standard and not SS for them.
Post #499773 3rd Feb 2016 12:17am
CarMan
Those on mine are 'proper' bolts and though the outside four are quite tidy even after 23 years the midde 6 (I think it is) are quite rusty) and I was planning to change for stainless, but it seems to me all those I can see for sale are torxs or allen heads. Now I'm not a rivet counter and my 90 is far from perfect but I'm just wondering what's best?
Post #503605 11th Feb 2016 7:33pm
mikeh501
Just get some a2-80 bolts of the right size (take one out and measure.) From Westfield fasteners or similar. You can choose whichever head you wish. Duralac or similar available from eBay.
Post #503632 11th Feb 2016 8:17pm
leeds
Duralac is a good anti corrosion paste but is not an anti seize paste which is useful for stainless nuts and bolts.
Brendan
Post #503676 11th Feb 2016 9:17pm
Stacey007
Sorry
couple of questions about these...
1) How do you undo them? I managed 2 with a screwdriver and torx bit but they are so tight I have nothing more job on...
2) The two I managed to remove don't appear to have a nut they just tighten up to the threaded panel?
so help please what do you use to undo them and do they have a bolt? on a puma Defender.
Thanks
Post #504354 13th Feb 2016 7:03pm
Page 1 of 3 123>
