Home > Maintenance & Modifications > cross member bolts easy to swap?
Page 2 of 3 <123>
1) Try a Torx bit on a ratchet, or have you tried that? Soak with WD40 the day before.
2) I believe they are captive I.e. They go into a threaded hole in the rear X member.
No nuts or anything behind.
(Pretty sure this is the case anyway)
Post #504356 13th Feb 2016 7:22pm
Stacey007
^ just ordered one Smile
ooh and yes I think your right captive... I could not think of the name, Bottle of wine down ooops
many thanks
Post #504359 13th Feb 2016 7:32pm
mikeh501
A screwdriver lol Rolling with laughter
Post #504375 13th Feb 2016 7:54pm
Stacey007
^ I know Shocked
It was hard work and thought it was going to snap !!
live an learn I did check my sockets but no torx ones Sad so gave up
Post #504384 13th Feb 2016 8:10pm
Birdy
France 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
"... so gave up"
That's the spirit! Now all you have to do is learn to give up before you even begin! My 2011 sits on the drive, has had nothing done to it and never will - other than scheduled servicing, of course - it'll become rusty and corroded in ten or twelve years, at which time I might or might not get some welding done to pass the MOT and/or do something about the cosmetics.
Until then I'll have had ten or twelve years of using it, not worrying about leaks, squeaks, rattles or whether enough stainless steel and Nakatenga bling will turn it into a silk purse.
Peter
Post #504529 14th Feb 2016 10:42am
Screbble
Stacey007 wrote:
^ I know Shocked
You did well to get the first lot out without a socket drive, so you're doing ok Thumbs Up
As others have said, use the time waiting for the new torx bit to arrive to give the bolts a good soaking with penetrating oil. You can get to the rear of 4 of them I recall. Yes they are 'captive' via nuts welded to a piece of angle iron on the rear cross member.
As a self-confessed Anorak, I took the opportunity to run an M8 tap through the holes when I'd got them out. I then coated the threads of the captive nut with copper grease. A spot of Duralac near the head (where the stainless touches the aluminium) is something I do, however I also use a very discreet M8 nylon washer behind the new stainless bolt head (it can withstand the torque setting).
A good coat of Dinitrol on the captive nuts and new bolts from underneath the wheel arch finishes the job.
There is a product called Tef Gel that supposedly stops the stainless on stainless cold welding (galling) and also prevents the stainless on aluminium galvanic corrosion. If you plan to replace a lot of the fixings with stainless, and there are mixed views regarding that, then it's worth investing in something to address the galling and the corrosion. Thumbs Up
I did say I was an Anorak! Whistle
My rear cross member and fixings look brand new - but the rest of the Landy looks crap Rolling with laughter
Still, the pointless fettling it keeps me out of trouble Thumbs Up
Post #504567 14th Feb 2016 11:41am
Stacey007
^ Many thanks
I'm more than happy tinkering with it and these sort of mods are cheap and I like it looking nice.
I've used copper grease on the ones I re fitted and also a nylon washer as well as the actual washer so hopefully I've done something right.
I hope when the torx socket arrives it makes the others easier to do. Right tool for the job and all that Smile
Post #504976 15th Feb 2016 8:04pm
Avelingporter
I am involved in the marine world where there a lot of stainless fixings. Tef gel is a must. Will be using it on the stainless I got from Brendan at the Peterborough show. It's just taken this long as my delivery was put back. It's nearly here now!!
Post #505020 15th Feb 2016 9:13pm
Stacey007
So my torx socket arrived and made the job much easier, I was actually surprised how easy they were to remove Very Happy
Embarassed Took them out polished the area round them, squirted copper grease in the hole after cleaning them out, then refitted new bolts with grease and a washer (nylon) against the bodywork.
Nice easy 'mod' looks better imho although this picture probably hard to tell Smile
Post #505271 16th Feb 2016 7:37pm
rustandoil
Well done Thumbs Up another job jobbed Thumbs Up
Post #505282 16th Feb 2016 7:55pm
Screbble
Looking good Thumbs Up Thumbs Up
Post #505333 16th Feb 2016 9:39pm
peanutbob
Resurrecting this thread…I’ve just replaced the six inner bolts which were easy enough. Do the outer bolts - 2 on each side have a nyloc nut on each end as the kit I purchased came with 10 bolts and 4 nuts? If so, that might be less easy to locate and replace the existing nuts if there are any.
Post #1013860 4th Nov 2023 9:26am
Screbble
I don’t recall them having nuts but I could be wrong - as it’s quite a while ago.
I thought that they are all fixed into an angle iron bracket which is fixed to the top of the crossmember and all 10 went into captive nuts?
You should be able to see if you remove the so-called mud guard under wheel arch?
Post #1013863 4th Nov 2023 9:32am
They shouldn't have nuts on. They screw into fixed threads. Darren
Post #1013864 4th Nov 2023 9:35am
peanutbob
Ok, many thanks all.
Post #1013866 4th Nov 2023 9:47am
Page 2 of 3 <123>
