- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Home > Td5 > Indicator daft question |
Mickysham
All my indicators work except the front passenger the wire was very short from the plug and only recently i decided to up date the lights and make it look a bit posher by changing all to the led but now this one light wont work i think ive pulled the wire out further up.. does it go into a 4 block like the older tdi?
The plug to attach to the light had broke for a long time so a temp fix of a bit of wire helped there but now want it sorted properly so what or where does that indicator wire go to?
Hopefully not confused ye
18th Jan 2016 11:16pm |
