Home > Td5 > Td5 alarm keeps going off
Page 2 of 2 <12
JWL
It would be worth getting someone with a code reader such as a Nanocom or Hawkeye etc and check the alarm settings and faults registered. You can disable as well if you want.
Post #493493 17th Jan 2016 9:55pm
achuakh
Singapore 2002 Defender 90 Td5 SW Oslo Blue
It really depends on what you set it to be. Not sure what the default is, but in order for this key in the lock to be read, you will need the original land rover 4 pin acuator on the driver's door. if you hacked it, like me, and didn't make the connection to those, then these features will not work.
You can disable key disarm as well, so meaning unlocking the door doesn't disarm the alarm, meaning you are forced to use the plip.
A neat feature is the 1min relock you can enable, in the event you accidentally pressed the unlock or your dog bit the remote and unlocked the car and you didn't open the doors, it relocks and arms after 1 minute. this is not set by default. From the land of the most expensive land rover defenders on planet earth. At �125k for a XS 110 csw and you get to own it only for 10yrs! Please find me a good reason to stay on this island.
Post #494106 19th Jan 2016 4:33pm
Millsy94
England 2003 Defender 90 Td5 PU Aintree Green
It's back!! Every time after I've washed it it plays up. Volumetric unplugged rear door sensor unplugged (was wet and badly corroded) still does it. On the events list on nanocom it's got door sill button. What is that when its at home? Cheers ed
Post #496010 24th Jan 2016 11:42pm
mk1collector
The pin switch on the a post is probably getting wet when washing it, try unscrewing it and see if there is anything obviously wrong and give it a spray with wd40. Ray
My build thread
Post #496015 25th Jan 2016 12:05am
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
As my previous post with a link.... get 3 new pillar switches, give it a try, worked for me Whistle
Post #496023 25th Jan 2016 4:22am
achuakh
Door sill is the lock from the inside on the door sill. Disco only. Def no. From the land of the most expensive land rover defenders on planet earth. At �125k for a XS 110 csw and you get to own it only for 10yrs! Please find me a good reason to stay on this island.
Post #497037 27th Jan 2016 3:50pm
Page 2 of 2 <12
