Home > Td5 > Td5 alarm keeps going off |
make shore door interior light switch are dry and in good working order
do you have battery backed alarm sounder power connector to it ok also how is your spider collection set my alarm off sometimes |
16th Jan 2016 7:10pm |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 |
Take the speaker out of the drivers footwell.
Shine torch into dash cavity Look for water near green box |
16th Jan 2016 7:13pm |
Millsy94 Member Since: 06 Jun 2013 Location: Gloucestershire Posts: 91 |
Ok will check all door switches tomorrow and green box. What is the battery backed alarm sounder?? Cheers for quick responses
16th Jan 2016 10:43pm |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 |
I had the same thing a while ago, tended to go off at 3am!
I bought a set of door contact recess switches for a few quid and fitted them, also unplug the movement sensor above the driver, more hassle than it's worth. http://www.ebay.co.uk/ulk/itm/221957372514 |
17th Jan 2016 5:37am |
Ah will try unplugging the sensor. It doesn't seem to play up if you lol with the key if that makes a difference
17th Jan 2016 9:16am |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1430 |
i'm pretty sure locking with the key disarms the interior motion sensor, as that way it donsn't go off when you lock the dogs/ kids in Might have found youre offending item
17th Jan 2016 10:03am |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
It's water in the door switches. Spray them with WD40 with the tube on the can so you get good penetration round the button. Lasts for years.
If that doesn't work, look for a fly or moth inside the cab. |
17th Jan 2016 12:10pm |
I don't think this is true and is a common misconception. I'll double check though |
17th Jan 2016 6:07pm |
Yep as suspected locking with key is identical as locking with plip
See here http://www.nanocom-diagnostics.com/uploads...0Guide.pdf You could verify this by locking with drivers window down via key wait 60secs and wave arm around inside. |
17th Jan 2016 6:13pm |
On mine it works if you lock with the key (which I occasionally do if the dog is in the car) the motion sensor doesn't set so the dog doesn't set the alarm off. I have also checked the motion sensor works with the alarm fob (just in case) and the alarm went off with me waving my arm inside. Ray
17th Jan 2016 6:27pm |
Ray,
Your alarm doesn't go off because you have a Lab & 110 This is just a combination of well behaved naturally lazy dog that lies down a long way from a crap sensor Go test it now by locking with key with driver window down. Ultrasonics should arm |
17th Jan 2016 6:54pm |
Justtellme Member Since: 23 Nov 2015 Location: Ottawa Posts: 310 |
My manual says to lock the car with the remote while one of the doors is open. Then close the door and voila the car is locked and alarmed but with the interior motion sensor now disabled. Thing is I have a stock TD5 2003 110 with alarm, no battery back up sounder fitted and no motion sensor fitted in the car, but everything else. Is this a normal setup? I bought mine second hand from Germany. Patrick |
17th Jan 2016 8:25pm |
It works on mine |
17th Jan 2016 9:01pm |
it also works if I leave the kids in the car while I nip into the shops, they sit in the middle row and they are never still Ray My build thread http://www.defender2.net/forum/topic17615.html |
17th Jan 2016 9:17pm |
