![]() | Home > Td5 > Td5 alarm keeps going off |
It would be worth getting someone with a code reader such as a Nanocom or Hawkeye etc and check the alarm settings and faults registered. You can disable as well if you want.
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 161 ![]() ![]() ![]() |
It really depends on what you set it to be. Not sure what the default is, but in order for this key in the lock to be read, you will need the original land rover 4 pin acuator on the driver's door. if you hacked it, like me, and didn't make the connection to those, then these features will not work.
You can disable key disarm as well, so meaning unlocking the door doesn't disarm the alarm, meaning you are forced to use the plip. A neat feature is the 1min relock you can enable, in the event you accidentally pressed the unlock or your dog bit the remote and unlocked the car and you didn't open the doors, it relocks and arms after 1 minute. this is not set by default. The defender has migrated, leaving the owner behind. |
The pin switch on the a post is probably getting wet when washing it, try unscrewing it and see if there is anything obviously wrong and give it a spray with wd40. Ray
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 ![]() ![]() ![]() |
As my previous post with a link.... get 3 new pillar switches, give it a try, worked for me
Door sill is the lock from the inside on the door sill. Disco only. Def no. The defender has migrated, leaving the owner behind. |
