Home > Maintenance & Modifications > What LED rear lights do I need to replicate this?
Page 1 of 3 123>
Stacey007
Hello
After spending ages on Google images looking at the back of Defenders.... Sad I know but I bet I'm not the only one Smile
I've decided I like this look for the back of my Defender,
3 lights in clear each side and the two red lights above. Like this (saying that I still don'y know RDX, wipac, NAS etc..)
This is the back of my defender, Has any one done this?
I guess I'm best just buying individual lights as most of the kits don't seen to offer this set up?
Post #484373 22nd Dec 2015 10:14am
Martin
Site Admin
All LED, or a mixture?
What order do you want the lamps at the bottom?
The top ones will pretty much have to be LED to get them to fit the shape of the body, unless you are willing to enlarge the hole in the capping to accommodate a bulb holder.
The inner ones at the bottom will need new holes drilling, but I'm sure you know that.
I think you will end up buying lamps separately to achieve this, yes.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #484381 22nd Dec 2015 10:26am
Cheshire110
Mud UK is the place you seek Thumbs Up Cheers, David
Post #484399 22nd Dec 2015 11:06am
Stacey007
Hello
Not sure what order to have the lights, additional reversing lamps would be good.
yes to led type though I think all round (back for now)
Will look on Mud UK
Post #484401 22nd Dec 2015 11:07am
Cheshire110
Here you go: couldn't find it for a min.
http://www.mudstuff.co.uk/products/electri...lamps.html
It's cheaper if you don't mind having your standard reverse and/or fog lights. Cheers, David
Post #484402 22nd Dec 2015 11:10am
Stacey007
Great ^
Gulp though... Seems I've chosen and expensive 'look'
Sad
Post #484403 22nd Dec 2015 11:12am
RRUK
there is a template that holds all three lights like that, I've seen it somewhere and now can't find it, give me a while and I will find it 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #484404 22nd Dec 2015 11:24am
Stacey007
great ^
Post #484406 22nd Dec 2015 11:26am
Cheshire110
The other thing you have to consider if you want LED indicators is which way to prevent the fast-flash they result in.
I will go for just fitting load resistors but you can also get replacement relays which solve this, however very few work perfectly - often resulting in no trailer light when towing or other issues. Cheers, David
Post #484407 22nd Dec 2015 11:26am
Indicators look like the KBX multi mount to me. They also look like LED's.
Post #484408 22nd Dec 2015 11:29am
Stacey007
^ So am I best keeping to std indicators as I don't want warning lights when towing?
Post #484410 22nd Dec 2015 11:30am
Cheshire110
Or fit load resistors with the LEDs as mud sell and that will be exactly the same Thumbs Up Cheers, David
Post #484411 22nd Dec 2015 11:31am
RRUK
Found it..
http://www.kbxupgrades.co.uk/kbx-nas-multi-mounts.php 2016 D4 HSE
Post #484413 22nd Dec 2015 11:33am
Stacey007
Post #484414 22nd Dec 2015 11:33am
The RDX relay and LED's work perfectly in tandem. If trailer has standard incandescent light buts it'll work as factory for the trailer light.
If it has LED's on trailer you can either fit resistors on trailer only or an audible warning device.
If you don't tow at all or tow with incandescent light trailer then there is zero issue.
I'd certainly not fit resistors myself to a Landy due to the heat problem, last but not least they then draw the same power or more as regular bulbs defeating the power draw difference between the two.
The Wipac relay and RDX both work seamlessly and both are plug and play and easily adjustable. I've been running all RDX for two years now with zero issues.
Post #484415 22nd Dec 2015 11:35am
Page 1 of 3 123>
