![]() | Home > Maintenance & Modifications > What LED rear lights do I need to replicate this? |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6662 ![]() ![]() ![]() |
All LED, or a mixture?
What order do you want the lamps at the bottom? The top ones will pretty much have to be LED to get them to fit the shape of the body, unless you are willing to enlarge the hole in the capping to accommodate a bulb holder. The inner ones at the bottom will need new holes drilling, but I'm sure you know that. I think you will end up buying lamps separately to achieve this, yes. ![]() ![]() |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2774 ![]() ![]() |
Mud UK is the place you seek
![]() Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3820 ![]() ![]() |
Hello
Not sure what order to have the lights, additional reversing lamps would be good. yes to led type though I think all round (back for now) Will look on Mud UK |
Here you go: couldn't find it for a min.
http://www.mudstuff.co.uk/products/electri...lamps.html It's cheaper if you don't mind having your standard reverse and/or fog lights. Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
Great ^
Gulp though... Seems I've chosen and expensive 'look' ![]() |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2025 ![]() ![]() |
there is a template that holds all three lights like that, I've seen it somewhere and now can't find it, give me a while and I will find it 2016 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
great ^
The other thing you have to consider if you want LED indicators is which way to prevent the fast-flash they result in.
I will go for just fitting load resistors but you can also get replacement relays which solve this, however very few work perfectly - often resulting in no trailer light when towing or other issues. Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20755 ![]() ![]() |
Indicators look like the KBX multi mount to me. They also look like LED's.
^ So am I best keeping to std indicators as I don't want warning lights when towing?
Or fit load resistors with the LEDs as mud sell and that will be exactly the same
Found it..
http://www.kbxupgrades.co.uk/kbx-nas-multi-mounts.php 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
Found the mount I think?
http://www.paddockspares.com/kbx9301-kbx-n...AkYG8P8HAQ or just a guard http://www.paddockspares.com/kbx8301-kbx-n...-pair.html |
The RDX relay and LED's work perfectly in tandem. If trailer has standard incandescent light buts it'll work as factory for the trailer light.
If it has LED's on trailer you can either fit resistors on trailer only or an audible warning device. If you don't tow at all or tow with incandescent light trailer then there is zero issue. I'd certainly not fit resistors myself to a Landy due to the heat problem, last but not least they then draw the same power or more as regular bulbs defeating the power draw difference between the two. The Wipac relay and RDX both work seamlessly and both are plug and play and easily adjustable. I've been running all RDX for two years now with zero issues. |
