![]() | Home > Off Topic > Towing without a B+E - I'm confused |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2731 ![]() ![]() |
All the quad trailers at work are un-braked and plated at 750kg or less for this very reason. It was actually a P8 that I found a massive pain behind my 90. Though it didn't have cage sides, which would improve the visibility. My dad has one which I borrowed to collect an engine (yes officer it's well under 500kg...) and it was a fiddle to reverse. Bounced around when empty too.
Now have an LM125G which tows like a dream behind the Land Rover. Don't know how I managed without it, a Defender without an accompanying big trailer is only half the story ![]() |
I have found the source of my confusion. The rules have changed (or at least the gov.uk website has) in the last year... yay.
I printed this out in November 2014 which clearly says MAM for 2013- and weight for 1997-2013: ![]() Click image to enlarge For me (as mentioned) that actually makes quite a big difference, and I'm a bit ![]() |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5087 ![]() ![]() ![]() |
They change it a few times im sure i remember them saying that the trailer test removed the trailer weight restriction when i did it eg any weight of trailer thats legal, where as before it was limit to 3500kg trailer and i bet its different now.
So as above a coupled braked 4ton trailer would be ok Mike |
At one point the 1997-2013 B+E didn't have a weight limit on the trailer, so you could get a tractor unit based on a van and tow mini-artic trailers.
Yes thats when i did mine Mike
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1369 ![]() ![]() |
to get round this problem, i did my class 1
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1596 ![]() ![]() ![]() |
There has always been a total train weight. Think it's 8250kg.
except that doesnt technically exist C+E Mike |
Boyd Member Since: 11 May 2014 Location: Le Saint Posts: 172 ![]() ![]() ![]() |
Just to avoid confusion as a number of people have quoted the old rules...
https://www.gov.uk/towing-with-car/driving...ou-can-tow From the 16th Jan last year there was a suttle change mainly impacting those that passed their test after Jan '97 (and before sometime in 2012) holding a category B license, now instead of it being the gross weight of the combined 'train' being 3500kg as a limit, it's the weight being the restriction I.e. You can tow a trailer with a greater gross weight than 750kg and more specifically greater than a 3500kg train gross as long as the 'train' weight is no higher than 3500kg. ![]() 2004 Santorini Black TD5 110 XS SW left hooker for sale! 2004 Alpine White TD5 110 left hooker (work in progress) |
Hold on, I think you've got it backwards?
It's gone from being actual train weight to plated maximum train weight. |
