Home > Off Topic > Towing without a B+E - I'm confused |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2647 |
All the quad trailers at work are un-braked and plated at 750kg or less for this very reason. It was actually a P8 that I found a massive pain behind my 90. Though it didn't have cage sides, which would improve the visibility. My dad has one which I borrowed to collect an engine (yes officer it's well under 500kg...) and it was a fiddle to reverse. Bounced around when empty too.
Now have an LM125G which tows like a dream behind the Land Rover. Don't know how I managed without it, a Defender without an accompanying big trailer is only half the story |
20th Dec 2015 2:43pm |
I have found the source of my confusion. The rules have changed (or at least the gov.uk website has) in the last year... yay.
I printed this out in November 2014 which clearly says MAM for 2013- and weight for 1997-2013: Click image to enlarge For me (as mentioned) that actually makes quite a big difference, and I'm a bit off they changed it without making any sort of a fuss about it. |
11th Jan 2016 6:28pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5035 |
They change it a few times im sure i remember them saying that the trailer test removed the trailer weight restriction when i did it eg any weight of trailer thats legal, where as before it was limit to 3500kg trailer and i bet its different now.
So as above a coupled braked 4ton trailer would be ok Mike |
11th Jan 2016 7:01pm |
At one point the 1997-2013 B+E didn't have a weight limit on the trailer, so you could get a tractor unit based on a van and tow mini-artic trailers.
11th Jan 2016 9:35pm |
Yes thats when i did mine Mike
11th Jan 2016 10:24pm |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1362 |
to get round this problem, i did my class 1
12th Jan 2016 6:50am |
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1581 |
There has always been a total train weight. Think it's 8250kg.
12th Jan 2016 7:44am |
except that doesnt technically exist C+E Mike |
12th Jan 2016 5:32pm |
Boyd Member Since: 11 May 2014 Location: Le Saint Posts: 172 |
Just to avoid confusion as a number of people have quoted the old rules...
https://www.gov.uk/towing-with-car/driving...ou-can-tow From the 16th Jan last year there was a suttle change mainly impacting those that passed their test after Jan '97 (and before sometime in 2012) holding a category B license, now instead of it being the gross weight of the combined 'train' being 3500kg as a limit, it's the weight being the restriction I.e. You can tow a trailer with a greater gross weight than 750kg and more specifically greater than a 3500kg train gross as long as the 'train' weight is no higher than 3500kg. 2003 Zambezi Silver TD5 110 XS SW overland prepped.... 2004 Santorini Black TD5 110 XS SW left hooker for sale! 2004 Alpine White TD5 110 left hooker (work in progress) |
12th Jan 2016 7:29pm |
Hold on, I think you've got it backwards?
It's gone from being actual train weight to plated maximum train weight. |
12th Jan 2016 9:24pm |
