![]() | Home > Td5 > Td5 injector loom OEM |
And importantly it works brilliantly if done right at the start ![]() ![]() Pop the top off the connector, fill it with instant gasket sealant, cap back on, leave to set for a day or so. Some more garket sealer around the O-rings when you install the loom and you are good. Or at least you stand a better chance of it not tracking down the wires to your ECU or dribbling out on to the aux belt. ![]() |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 965 ![]() ![]() ![]() |
Good description, that is what I was referring to about sealing it. Here the best stuff to use is a product called “Right Stuff”. Canadian Tire sells it
![]() 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6161 ![]() ![]() ![]() |
I filled mine with some tigerseal as I had a tube opened up already.
Hasn't caused any problems in 10 years yet. |
