Home > Td5 > Td5 injector loom OEM
Justtellme
Canada 2003 Defender 110 Td5 SW Oslo Blue
I just received subject item from Paddocks.
I ordered an OEM one and it looks pretty good relative to the ones I've seen on line but it came in a Britpart box which scares me a bit.
It has the brand name "Cannon" on the top of the main harness round connector. Normally I wouldn't expect Chinese copies to have any branding on them. Is this really an OEM manufactured one?
Interestingly it seems to have been manufactured in 2012 according to the sticker on the side.
Patrick
Post #483184 17th Dec 2015 8:25pm
PaulMc
ITT Cannon make the 8-way sealed connector -
The injector connectors are made by TE Connectivity and could have any of the following branding on them -
AMP, Tyco, TE, or just the TE Connectivity logo.
Bosch and Delphi also make connectors that fit the injectors - but, these aren't usually used.
The OE supplier of harnesses to Land Rover are Leoni Wiring Systems.
If your injector harness was sold as 'OEM' - then it should have been made by Leoni, using quality connectors - even in a Br(Sh)itpart box.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Paul.
Post #483196 17th Dec 2015 8:56pm
Swac3
ITT Cannon make a huge variety of connectors including MIL spec and Aircraft stuff but who can say if its a genuine part or not ? fakers aren't adverse to stamping brand names onto copies tho as you say usually they don't bother.
Unless you're desperately in need of the truck, it looks like a call to your supplier is in order.
Lol Paul beat me to it 3 Landrovers
Post #483197 17th Dec 2015 8:59pm
Justtellme
Thanks Paul and Swac,
Looking closer at the loom it has the ITT Cannon plug, each of the injector plugs has the Stylized TE logo on them and the wiring looks to have Raychem 16 200C etched on them.....some look like it might be T6 200C
On the wiring loom protector there is a sticker with:
51259988 MODK. 14:32 BRD 01
AMR6103 ISSB 020612 Wk 22
Based on the ITT Cannon and Tycho branded connectors that you have quoted and the fact that Raychem wiring is a Tycho brand, (from their website....T6 200C continuous operating in -40 to +200C temps and resistant to all automotive fluids including oil submersion) I'm leaning towards this being a legitimate loom and worth installing from a newbie perspective.
Thoughts?
Patrick
PS...my wife is getting pretty annoyed with me having an automotive wiring loom on the bedside table while I search online.
Post #483217 17th Dec 2015 9:39pm
PaulMc
Patrick,
From your description, I would say that you have a genuine, or OEM quality harness Thumbs Up
Rolling with laughter
She'd probably have a fit at the boxes of connectors, reels of cable, and Land Rover harnesses that I've got piled-up in my house Laughing
Fortunately for me, my wife has been very understanding (so far) Whistle
. Paul.
Post #483224 17th Dec 2015 9:55pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
The britpart ones are actually OEM! I fitted one a while back.
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #483266 18th Dec 2015 12:03am
duckworthparts
Site Sponsor
Britpart don't do their own version, only OEM
a lot of OEM parts from britpart are now re-packed into britpart boxes with OEM written under the part number. https://www.facebook.com/duckworthparts
Send a paypal payment direct using this link www.paypal.me/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: danroberts@duckworthlandrover.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Can also supply OEM & Aftermarket parts
Post #483310 18th Dec 2015 10:43am
annette
Costa Rica
PaulMc wrote:
Patrick,
Normal, we understand electronics better than our male workmates Razz
so did you find this beauty? Come on I need this on my bedside table. I have a complete loom that is useless cause for once poxypol didn't work Fixing Land Rovers in rural Guanacaste
Post #732318 1st Oct 2018 8:56pm
geobloke
Good to know Dan Thumbs Up
Post #732366 2nd Oct 2018 7:40am
derbywill
I had a couple of Britpart ones and both have been OEM looms.
Will 2005 90 XS
1968 88” 2A 200tdi
2002 110 Hardtop
Post #732443 2nd Oct 2018 11:40am
lightning
Same here, it was well known that you could order the harness from Britpart and in the box was an OEM unit, for about half the price of OEM!!
I’ve done it twice.
Post #732594 2nd Oct 2018 8:26pm
sandu
Moldova 2000 Defender 110 Td5 SW Epsom Green
I am just curious if these connectors could exclude the leaking problem of the injector harness?
Did anyone tried them? LR DEF 110 TD5, 2000.
LR DISCO-2 TD5, 2001.
ARB Difflocks, front + rear.
Ashcroft CV Joints + Halfshafts..
Transferbox 1.410 ratio.
Warn M12000 + Warn 9.5xp
BFG KM2 255/85R16
Maxxis Creepy Crawler 255/85R16
Post #783983 30th Jul 2019 8:48am
miker
They all leak eventually!
Post #783989 30th Jul 2019 9:05am
They only leak if you fail to seal them properly before installation. They will all leak if you fit them as supplied by the manufacturer, since they are being used in a way in which the manufacturer did not intend.
Post #784013 30th Jul 2019 11:03am
4RF RDS
Re: Td5 injector loom OEM
Patrick
FWIW (And I am not defending Britpart). Because it came in a Britpart box does not mean it is not genuine . Britpart supplies OEM, genuine, and pattern parts. Generally speaking Britpart brand is pattern. Regardless, seal the plug hole with “Right stuff” sealant when you reassemble it. Thumbs Up
Food for thought. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
H. L. Mencken (1880 - 1956)
Post #784047 30th Jul 2019 1:32pm
