Home > Td5 > Td5 injector loom OEM
Page 2 of 2 <12
geobloke
blackwolf wrote:
They only leak if you fail to seal them properly before installation. They will all leak if you fit them as supplied by the manufacturer, since they are being used in a way in which the manufacturer did not intend.
And importantly it works brilliantly if done right at the start Thumbs Up Thumbs Up
Pop the top off the connector, fill it with instant gasket sealant, cap back on, leave to set for a day or so. Some more garket sealer around the O-rings when you install the loom and you are good.
Or at least you stand a better chance of it not tracking down the wires to your ECU or dribbling out on to the aux belt. Rolling Eyes
Post #784059 30th Jul 2019 4:26pm
^^ Exactly! You need to fill the inside of the connector shell with insulating electrical 'potting compound' or a similar product. The main problem with this loom is the result of the connector shell filling with oil which then tracks down each wire inside the insulation, along the interstices between the individual conductor strands. If the connector is properly potted, this cannot happen.
The connector was not intended to be submerged, which, in effect, it is.
Post #784063 30th Jul 2019 4:43pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Good description, that is what I was referring to about sealing it. Here the best stuff to use is a product called “Right Stuff”. Canadian Tire sells it Thumbs Up 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #784074 30th Jul 2019 5:12pm
I filled mine with some tigerseal as I had a tube opened up already.
Hasn't caused any problems in 10 years yet.
Post #784087 30th Jul 2019 6:07pm
Page 2 of 2 <12
