Home > Maintenance & Modifications > Judder on take off and reverse |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20576 |
Worn prop UJ's? When was the clutch last changed?
14th Dec 2015 6:59pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17538 |
DMF and/or clutch, a very common occurrence.
14th Dec 2015 7:01pm |
Paintedpilgrim Member Since: 28 Nov 2015 Location: Hereford Posts: 49 |
Not sure on the clutch, feels fine other that this, how would I check the uj for wear? What is the dmf please?
14th Dec 2015 7:04pm |
DMF = Dual Mass Flywheel.
No DMF on mine as it's a Puma, however I had similar problems and it was the clutch. They told me the clutch was worn but not really badly but the friction plate was pitted. That might explain the juddering which I had too. |
14th Dec 2015 7:30pm |
Ah I see, sounds expensive to me! How could I tell if it is the clutch or dmf?
14th Dec 2015 7:56pm |
That's the problem, you can't unless it's apart.
And yes, it is expensive! It got worse for me until one day it suddenly and unexpectedly got so bad it was slipping all the time in every gear. You'd change, bring up the clutch and no drive until about 2 secs later. I just got home and then needed recovery to dealer. Other members here are more experienced on the mechanics and spannering side than me. It can't be prop balancing as that'd be during drive not moving off. UJ's would need to be checked for rotational play in them, I'm not sure how much play they should have as standard. They do have tolerances of a certain amount of play in them from new. |
14th Dec 2015 8:23pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 |
Is it better after everything has warmed up a bit after a few miles?
When does it do it, as soon as the clutch starts to bit or just before you have finished raising the pedal? Steve 02' 110 TD5 Double Cab Rebuild Thread |
14th Dec 2015 9:42pm |
Yeah it is a bit better once warmed up and it does it just as the clutch bites
14th Dec 2015 9:46pm |
It doesn't matter how gently you disengage the clutch it happens, but it's fine once your going along although you do have to lift the clutch slowly after a gear change
14th Dec 2015 9:48pm |
Toby60 Member Since: 06 Dec 2014 Location: Cheshire Posts: 28 |
I have a 2002 TD5 90 that has some clutch judder when the vehicle is first used and once warmed up it goes away. It occurs from when the clutch bites to the fully released position. The vehicle has done 123,000 miles and is on its original clutch. I put it down to either dampness or a small amount of oil on the clutch plate. Although due to the mileage, the clutch could be on its way out but it does not slip at any time.
Is the judder something I should be concerned about? ------------------------------------------------ 2002 TD5 90 HT County |
14th Dec 2015 10:21pm |
Jeez, 123k on original clutch. Puma one's must be made of cheese!
Mine was changed at 44k. |
14th Dec 2015 11:41pm |
Mines done 143k but I didn't get any history with it so have no idea if the clutch has been done
15th Dec 2015 7:38am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5788 |
Take props off and throughly check all the UJ's and slides, but it does sound more like the DMF to me.
Sorry Andy |
15th Dec 2015 9:46am |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3786 |
How much is a clutch on a puma?
15th Dec 2015 11:29am |
