Home > Maintenance & Modifications > Rear load mat issue
Terryb
Rear load mat issue
Hi all, just purchased a new load mat for my 90, problem is I have load tie points (6no) which are bolted thru the body, the picture of the mat I bought showed the same but could not make out if they had cut out round the ties or refixed them over the top of the mat , if I cut round the ties I am worried that the mat may split further than the cut but if I refix ties on top then it becomes a problem removing the mat forc leaning etc Any thoughts appreciated cheers terry b
Post #476203 25th Nov 2015 9:03pm
ibexman
I put mine over the top of them never use them Whistle
Post #476206 25th Nov 2015 9:12pm
JAY BOY
Wales
I took all mine off, installed the mat made new holes and reinstalled. job done.
Pics in my gallery Thumbs Up
Post #476210 25th Nov 2015 9:20pm
Not quite sure if it is you issue or not but there is a SW and HT variant to load mats.
You may well have the appropriate mat but is it? If so then just a pain in the ass.
Post #476253 25th Nov 2015 11:27pm
ManCub
United Kingdom 1991 Defender 90 200 Tdi HT Tamar Blue
I did the same as Jay. Takes 10 minutes and helps to keep the mat in place when dogs are jumping in and out.
Post #477630 30th Nov 2015 12:51pm
discomog
I've had numerous vehicles with tie points over the years and not used them once - am I missing out on something? Just put the mat on top of them. Did think about strapping the wife down in the back of the Volvo estate but that was many years ago when the testosterone was overflowing.
Post #477694 30th Nov 2015 3:55pm
ManCub
Brilliant.
I remember doing the same originally (not strapping the wife down but putting the load mat over the lashing points).
Although it came with self adhesive strips the lashing points meant it bulged out and the constant spinning of 5 spaniels was too much; it kept slipping off the arches.
Off it came, lashing points poked through and Bob's your Auntie's Hubby.
Go with whatever suits. Could never find ratchet straps strong enough to hold my wife; especially not during the January sales. Smile
Post #477752 30th Nov 2015 6:34pm
jst
exmoor trim kit from the OP description - rear three peice? great bit of kit, have one in the hardtop, i just refitted the tie downs after fitting the mat. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #477825 30th Nov 2015 9:29pm
CarMan
Hope it's ok to resurrect an old thread but what mats are you guys using in Puma's. I understood the genuine LR mat that goes over the wheel arches doesn't fit post TD5 so I bought just the genuine floor mat and it's too small in all dimensions!
Post #521580 6th Apr 2016 4:43pm
Peter D
I've recently bought a new LR Defender rear load mat STC4629 from eBay for £129. Fits my Puma 90HT like a glove, just needed an inch or so trimmed off by the rear speakers.
I removed the tie downs and drilled bolt holes in the rubber mat and then refitted them on top, this will also help hold the mat in place.
It's a bit dark in the garage, but here is a couple of photos;
Regards
Post #522017 7th Apr 2016 8:24pm
CarMan
Hey Peter thanks very much for that you've made my day! I decided today to go that route and so glad I did - looking forward to it arriving Monday and getting it fitted. Looks like you also have the TGE side panels that I plan to fit Smile
Post #522033 7th Apr 2016 8:45pm
jst
looks good, now overlay it with the exmoor trim kit for better soundproofring? Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #522122 8th Apr 2016 8:52am
Swac3
Just did mine earlier in the week same as Peter D went for the genuine LR mat from the stealer, oddly it doesn't show up as for the puma on their system, he said something about the part number doesn't cross over ?
However fits really well, I put mine over the lashing points which does make it bulge ever so slightly in those places but definitely not an issue so far as i'm concerned.
Its not particularly cheap, but then it does have a great big Land Rover logo on so..........
Gary 3 Landrovers
Post #522132 8th Apr 2016 9:09am
