Home > Maintenance & Modifications > Rear load mat issue |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2945 |
I put mine over the top of them never use them
25th Nov 2015 9:12pm |
JAY BOY Member Since: 04 May 2010 Location: Not here Posts: 1706 |
I took all mine off, installed the mat made new holes and reinstalled. job done.
Pics in my gallery |
25th Nov 2015 9:20pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20380 |
Not quite sure if it is you issue or not but there is a SW and HT variant to load mats.
You may well have the appropriate mat but is it? If so then just a pain in the ass. |
25th Nov 2015 11:27pm |
ManCub Member Since: 18 Mar 2014 Location: Lydbrook Posts: 42 |
I did the same as Jay. Takes 10 minutes and helps to keep the mat in place when dogs are jumping in and out.
30th Nov 2015 12:51pm |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2527 |
I've had numerous vehicles with tie points over the years and not used them once - am I missing out on something? Just put the mat on top of them. Did think about strapping the wife down in the back of the Volvo estate but that was many years ago when the testosterone was overflowing.
30th Nov 2015 3:55pm |
Brilliant.
I remember doing the same originally (not strapping the wife down but putting the load mat over the lashing points). Although it came with self adhesive strips the lashing points meant it bulged out and the constant spinning of 5 spaniels was too much; it kept slipping off the arches. Off it came, lashing points poked through and Bob's your Auntie's Hubby. Go with whatever suits. Could never find ratchet straps strong enough to hold my wife; especially not during the January sales. |
30th Nov 2015 6:34pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8033 |
exmoor trim kit from the OP description - rear three peice? great bit of kit, have one in the hardtop, i just refitted the tie downs after fitting the mat. Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
30th Nov 2015 9:29pm |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1861 |
Hope it's ok to resurrect an old thread but what mats are you guys using in Puma's. I understood the genuine LR mat that goes over the wheel arches doesn't fit post TD5 so I bought just the genuine floor mat and it's too small in all dimensions!
6th Apr 2016 4:43pm |
Peter D Member Since: 03 Mar 2016 Location: Surrey Posts: 28 |
I've recently bought a new LR Defender rear load mat STC4629 from eBay for £129. Fits my Puma 90HT like a glove, just needed an inch or so trimmed off by the rear speakers.
I removed the tie downs and drilled bolt holes in the rubber mat and then refitted them on top, this will also help hold the mat in place. It's a bit dark in the garage, but here is a couple of photos; Click image to enlarge Click image to enlarge Regards |
7th Apr 2016 8:24pm |
Hey Peter thanks very much for that you've made my day! I decided today to go that route and so glad I did - looking forward to it arriving Monday and getting it fitted. Looks like you also have the TGE side panels that I plan to fit
7th Apr 2016 8:45pm |
looks good, now overlay it with the exmoor trim kit for better soundproofring? Cheers
8th Apr 2016 8:52am |
Swac3 Member Since: 21 Feb 2015 Location: Aberdeen Posts: 363 |
Just did mine earlier in the week same as Peter D went for the genuine LR mat from the stealer, oddly it doesn't show up as for the puma on their system, he said something about the part number doesn't cross over ?
However fits really well, I put mine over the lashing points which does make it bulge ever so slightly in those places but definitely not an issue so far as i'm concerned. Its not particularly cheap, but then it does have a great big Land Rover logo on so.......... Gary 3 Landrovers |
8th Apr 2016 9:09am |
