Home > In Car Electronics > Spot light switch wiring.... |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2927 |
I have done a search and got about 90% of the info but I have a specific question... My rack lights loom from Mobilecentre has 2 pins that go into 1 and 5 in the landrover spot switch.... So I am assuming that I can just tap into a neighbouring switch for the illumination feed?? Into slot 2. But what about the switch ground?? Do I need it?
Thanks Andy Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
18th Oct 2015 11:44am |
mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772 |
Paulmc posted this helpful diagram a while ago.
Click image to enlarge Hope it helps Ray My build thread http://www.defender2.net/forum/topic17615.html |
18th Oct 2015 12:03pm |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 |
From memory you'll need the ground for the illumination, I just took both off neighbours
18th Oct 2015 12:04pm |
Yeah have seen that one...its the switch ground I need to get from another switch. Anyone know which pin is ground in either the rear wiper or washer switch? Andy
18th Oct 2015 12:09pm |
Yeah think ur right.. It easy to find the illumination feed as I can read 12v with the side lights on... I guess the ground wire in a switch won't have any volts? Andy
18th Oct 2015 12:16pm |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 504 |
The switch earths are Black wires - On pin 4 on the rear wiper switch On pin 2 on the rear washer switch The switch illumination lives are on Red/Orange wires - On pin 2 on the rear wiper switch On pin 5 on the rear washer switch . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
18th Oct 2015 12:17pm |
Perfect Paul.
Thanks Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
18th Oct 2015 12:18pm |
