Home > In Car Electronics > Spot light switch wiring....
mcma1
I have done a search and got about 90% of the info but I have a specific question... My rack lights loom from Mobilecentre has 2 pins that go into 1 and 5 in the landrover spot switch.... So I am assuming that I can just tap into a neighbouring switch for the illumination feed?? Into slot 2. But what about the switch ground?? Do I need it?
Thanks
Andy Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #464286 18th Oct 2015 11:44am
mk1collector
Paulmc posted this helpful diagram a while ago.
Hope it helps Ray
My build thread
Post #464289 18th Oct 2015 12:03pm
Tiger
From memory you'll need the ground for the illumination, I just took both off neighbours
Post #464290 18th Oct 2015 12:04pm
mcma1
Yeah have seen that one...its the switch ground I need to get from another switch. Anyone know which pin is ground in either the rear wiper or washer switch? Andy
2014 Corris 110 SW
LS3 V8 build...
Post #464293 18th Oct 2015 12:09pm
PaulMc
You need the earth on pin 4, as the switch switches the relay's coil to earth, from pin 1 to pin 4
The connection on pin 5 is so that the switch's tell-tale LED illumniates when the lamps are on.
The night-time illumination for pin 2, can be taken from an adjacent switch.
Does the kit not have any instructions with it Question
. Paul.
Post #464294 18th Oct 2015 12:10pm
mcma1
Yeah think ur right.. It easy to find the illumination feed as I can read 12v with the side lights on... I guess the ground wire in a switch won't have any volts? Andy
2014 Corris 110 SW
LS3 V8 build...
Post #464295 18th Oct 2015 12:16pm
PaulMc
The switch earths are Black wires -
On pin 4 on the rear wiper switch
On pin 2 on the rear washer switch
The switch illumination lives are on Red/Orange wires -
On pin 2 on the rear wiper switch
On pin 5 on the rear washer switch
. Paul.
Post #464296 18th Oct 2015 12:17pm
mcma1
Post #464298 18th Oct 2015 12:18pm
