Home > Td5 > Locking question |
Mine does that when a door is open....could be you've got a broken microswitch cable on one of the doors or a switch is knackered??? Whip the switches out have a good look, check them out with a voltage/continuity tester if able, wee squirt of WD and have another go!
Good luck! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
18th Sep 2010 1:49pm |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2625 |
Thanks
I'll give it agao in a minute |
18th Sep 2010 2:34pm |
SiWhite Member Since: 19 Jan 2010 Location: North Hampshire Posts: 455 |
My father's old 300Tdi Disco used to do that - I think there is an option when you access the Alarm ECU with diagnostics to enable or disable it. My blog - www.anacreinhampshire.blogspot.co.uk
110 TD5 BuildHERE - sold! 110 Tdci Build HERE - sold! Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender! |
BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785 |
I've know that to happen in the bonnet isn't closed properly
18th Sep 2010 3:20pm |
Hi BigRuss
Take a derserved bow it is the bonnet switch Cured in the short term by a ball of gaffer tape placed on top of the switch!!! At least i wont wake the neighbours up when i get back tonight Where would the world be without gaffer tape - luv it Cheers Mark |
18th Sep 2010 3:48pm |
Excellent result....Good to hear! If you go through life with your head in the sand....all people will see is an ar5e!!
18th Sep 2010 4:46pm |
Always happy to help I did read in and old LRO that with enough gaffa tape you can use it as a tow rope for vehicle recovery! |
18th Sep 2010 6:46pm |
