![]() | Home > Td5 > Locking question |
Mine does that when a door is open....could be you've got a broken microswitch cable on one of the doors or a switch is knackered??? Whip the switches out have a good look, check them out with a voltage/continuity tester if able, wee squirt of WD and have another go!
![]() Treat every day as if it is your last....one day you will be right!! |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2655 ![]() ![]() ![]() |
Thanks
I'll give it agao in a minute ![]() |
SiWhite Member Since: 19 Jan 2010 Location: North Hampshire Posts: 455 ![]() ![]() ![]() |
My father's old 300Tdi Disco used to do that - I think there is an option when you access the Alarm ECU with diagnostics to enable or disable it. My blog - www.anacreinhampshire.blogspot.co.uk
110 TD5 BuildHERE - sold! 110 Tdci Build HERE - sold! Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender! |
I've know that to happen in the bonnet isn't closed properly
Hi BigRuss
Take a derserved bow it is the bonnet switch ![]() ![]() ![]() Cured in the short term by a ball of gaffer tape placed on top of the switch!!! At least i wont wake the neighbours up when i get back tonight Where would the world be without gaffer tape - luv it Cheers ![]() Mark |
Excellent result....Good to hear!
Always happy to help ![]() I did read in and old LRO that with enough gaffa tape you can use it as a tow rope for vehicle recovery! |
