Home > Td5 > Locking question
markb110
Locking question
Hi All
Not used the 90 for the last three weeks, been sat unlocked in the garage.
When locking the doors via the handset (2002 with central locking) the horn beeps twice as the doors lock.
Cant seem to find a reason why in the hand book - any ideas?
All doors and bonnet are shut
Cheers in advance
Mark
Post #40808 18th Sep 2010 11:47am
K9F
Mine does that when a door is open....could be you've got a broken microswitch cable on one of the doors or a switch is knackered??? Whip the switches out have a good look, check them out with a voltage/continuity tester if able, wee squirt of WD and have another go!
Thumbs Up Good luck! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #40813 18th Sep 2010 1:49pm
markb110
Thanks
I'll give it agao in a minute
Thumbs Up
Post #40815 18th Sep 2010 2:34pm
SiWhite
United Kingdom 2013 Defender 110 Puma 2.4 USW Stornoway Grey
My father's old 300Tdi Disco used to do that - I think there is an option when you access the Alarm ECU with diagnostics to enable or disable it. My blog - www.anacreinhampshire.blogspot.co.uk
110 TD5 BuildHERE - sold!
110 Tdci Build HERE - sold!
Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender!
Post #40816 18th Sep 2010 2:34pm
BigRuss
I've know that to happen in the bonnet isn't closed properly
Post #40817 18th Sep 2010 3:20pm
markb110
Hi BigRuss
Take a derserved bow it is the bonnet switch Bow down Bow down Bow down
Cured in the short term by a ball of gaffer tape placed on top of the switch!!!
At least i wont wake the neighbours up when i get back tonight
Where would the world be without gaffer tape - luv it
Cheers Thumbs Up
Mark
Post #40819 18th Sep 2010 3:48pm
K9F
Excellent result....Good to hear! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #40823 18th Sep 2010 4:46pm
BigRuss
markb110 wrote:
Hi BigRuss
Cheers Thumbs Up
Mark
Always happy to help Thumbs Up
I did read in and old LRO that with enough gaffa tape you can use it as a tow rope for vehicle recovery!
Post #40835 18th Sep 2010 6:46pm
