![]() | Home > Maintenance & Modifications > Door seal adhesive? |
I recently took the drivers side seal off to facilitate removal of the pillar trim for routing a new wire. I was surprised how much drill swarf dropped out of the headliner on seal removal. My seal wasn't glued at all and went back on a treat. Maybe on build they have a mastic gun on standby just in case??? If you go through life with your head in the sand....all people will see is an ar5e!!
parktag Member Since: 30 Sep 2008 Location: Brittany Posts: 366 ![]() ![]() ![]() |
My dealer crimped mine back into position with a special tool. No problems since. 130 crew cab
98 V8 Disco |
Will do mate
![]() Might get round to it on Saturday |
I used this as extra sealing on my Snorkel....Worked a treat, is clear and should do the job you require it to...
http://nextday.diy.com/app/jsp/product/pro...ctId=92565 ![]() Treat every day as if it is your last....one day you will be right!! |
Thats what i used Mal worked fine door seal still inplace
Does what is says on the tin! (Well tube actually)
![]() The Works! It is obviously fit for exactly that purpose then as Fekete states... ![]() Treat every day as if it is your last....one day you will be right!! |
