Home > Maintenance & Modifications > Door seal adhesive?
Page 2 of 2 <12
K9F
I recently took the drivers side seal off to facilitate removal of the pillar trim for routing a new wire. I was surprised how much drill swarf dropped out of the headliner on seal removal. My seal wasn't glued at all and went back on a treat. Maybe on build they have a mastic gun on standby just in case??? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #40199 8th Sep 2010 6:12pm
parktag
France 2008 Defender 130 Puma 2.4 HCPU Zermatt Silver
My dealer crimped mine back into position with a special tool. No problems since. 130 crew cab
98 V8 Disco
Post #40200 8th Sep 2010 6:32pm
110SEB
Yup, Justin, that's exactly the problem I have. I too thump them back into place but will buy some contact adhesive too.
The thing is, with the seals sagging a bit, it's just yet another route for water to creep in, trickle down and soak the carpets! And now autumn/winter is on the horizon i want to get it done.
Let me know how you get on and which adhesive you bought, Boy!
Thanks all.
Seb
Post #40238 9th Sep 2010 8:09pm
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
Will do mate Thumbs Up
Might get round to it on Saturday
Post #40240 9th Sep 2010 8:14pm
K9F
I used this as extra sealing on my Snorkel....Worked a treat, is clear and should do the job you require it to...
http://nextday.diy.com/app/jsp/product/pro...ctId=92565
Post #40241 9th Sep 2010 8:23pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Thats what i used Mal worked fine door seal still inplace Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #40242 9th Sep 2010 8:24pm
K9F
Does what is says on the tin! (Well tube actually) Laughing
The Works!
It is obviously fit for exactly that purpose then as Fekete states... Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #40243 9th Sep 2010 8:28pm
Page 2 of 2 <12
