![]() | Home > My Defender > Corris 110.... |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2939 ![]() ![]() |
Went to fit the dirt defender, the factory chequer plate is thicker as it has foam pads and it also curves underneath the sill... I was going to end up with an obvious gap so I will just neatly trim the plate next. Also gave me a chance to clean all the crap caught under them and replace the rubbish LR fixings.
![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
Finished this off this evening, with the chequer plate off and dirt defenders on I was able to measure down from the sill holes to the dirt defender as its at an angle...
![]() Click image to enlarge Both cut and a fresh coat of satin black put on... ![]() Click image to enlarge All fitted back on. ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
![]() Click image to enlarge ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
Def much more power, I will need to mess about with the settings on the HU but so far so good.
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1776 ![]() ![]() ![]() |
If you don't mind me asking, where have you run your various cabling from switches to lights etc?
dont mind at all. I have brought the rack lights in using the front rack brackets to avoid drilling then down the usual A pillar into the dash and the then under the carpet on the gearbox tunnel into the cubby... Laser come through the bulkhead grommet with the high beam feed.
Got some Corris covers from urban truck, good finish. Just need a heat gun to fit these but very happy with them.
![]() Click image to enlarge New front seats should hopefully arrive tomorrow. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
Cheers! I think I'm going to go bulkhead grommet for the stuff on the front end, then roofrack lights will go to a socket on the rear of the tub at high level. |
John110 Member Since: 20 Nov 2011 Location: Co. Meath Posts: 106 ![]() ![]() ![]() |
Stunning. Great read for the past hour or so. I cannot decide which I would rather the 110 or the RS6
![]() Workmanship is top class. Well done! For those who understand, no explanation is needed... For those who do not understand, no explanation is possible |
My loyalty is with the defender...
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10940 ![]() ![]() |
Same as mcma1
Oakseywick Member Since: 20 Dec 2014 Location: Cirencester Posts: 1002 ![]() ![]() ![]() |
Andy just realised the "nice A6" as I posted previously is a RS6 my apologies that is my other dream car
Lol wife took the RS6 off me, she is getting better mpg than me in the 110!! Andy
Today's job...
