Home > Maintenance & Modifications > Fault finding rear axle, help please
67_6Cyl
France
Hi all......
Defender 110 CSW 2007 Puma TD4
Problem:
Generally a crappy ride, and vibration at 110 km/h - no clear cause for this, but appears to be more from the rear axle, and the axle is noisy.
Now, over the last 2 weeks there has started to be an excessive tyre wear on the (UK) O/S rear tyre. It is a band at the outside of the tyre, that goes all the way round.
Where should I start troubleshooting, bushes? Wheel bearings? Or the rear differential?
Thanks,
Jon
Post #438910 19th Jul 2015 1:42pm
sharkey964
France 2007 Defender 90 Puma 2.4 XS CSW Santorini Black
Hi Jon,
Wheel bearings would be a good place to start.
Then if its not that check everything the could cause a diference to the wheel geometry.
Lower link bar bushes could be worn,or loose.
Check wheel nuts aren't loose.
Marc
Post #438911 19th Jul 2015 2:18pm
67_6Cyl
France
Just spent 2 hours under the car.
The wheel bearings feel fine, and there isn't abnormal play in the diff. However, both panhard rod bushes and the trailing arm (where it joins the chassis) look very sad.
New bushes will be bought tomorrow.
Jon
Post #438940 19th Jul 2015 5:14pm
jst
how many miles
vibration likely to be prop balance and or UJs need doing.
tyres wear, pressures, bushes or alignment issue. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #438987 19th Jul 2015 9:05pm
How long are UJ's supposed to have life expectancy wise?
Post #438998 19th Jul 2015 9:44pm
67_6Cyl
France
200,000 kms......
Props are ok. They were done last year, and I couldn't find any play in the UJs. The tyres are worn, but balanced about 9 months ago, and pressures are correct (trailair monitor).
HTH
Jon
Post #439016 20th Jul 2015 5:09am
jst
Does it stop in a straight line?
For tyre wear to develop nd be noticeable in two weeks it would be something noticeable I would of thought.
Has vibration started at same time?
Props may if been done last year but doesn't mean uj hasn't gone or bal weight come off, no best in them or play checked when off? Or stiff, ie new uj not settled right? Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #439022 20th Jul 2015 6:15am
67_6Cyl
France
Yes it stops in a straight line. - propshafts off yesterday, the weights are on, in v good condition generally, UJ's not "stiff", but OK.
After looking yesterday, and tightening up the saddest of the Panhard rod bushes she was much better this morning, much quieter, and far less vibration - it was noticeable how sad the bush was, I was able to tighten the bolt by about 2mm........
I'll go with new panhard rod bushes, and then I'll do the trailing arm bushes.
Best
Jon
Actually, on the rear it's a sway arm , anti roll bar, or something isn't it?
Post #439035 20th Jul 2015 7:33am
jst
vibration is more likely to be something rotational in my experience if it occurs at a certain speed and is more than a rattle. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #439168 20th Jul 2015 8:02pm
67_6Cyl
France
I suspect that I actually have multiple things making noise / vibration.
The first to attack was the rear as there is clear uneven tyre wear. As said at the start of the thread this is quite probably linked to axle location. Having changed the anti roll bar bushes last night the beast is much improved and I have removed several bad points, and I hope that tyre wear will become normal.
Over the next couple of weeks I'll try and nail down the other vibrations one by one, but having tested everything rotational, either I am a useless tester, or it's not an immediately obvious problem. The only thing that I haven't been able to test is the transfer box......
Post #439223 21st Jul 2015 5:50am
Screbble
Stupid question.....(there's no such thing is there?).....
How/where do you get the props balanced?
On or off car?
I'll get my coat.....
Post #439228 21st Jul 2015 6:37am
67_6Cyl
France
it needs a special machine.
I went to a local HGV garage, and they did it for a very reasonable fee.
Jon
Post #439245 21st Jul 2015 7:31am
Rickydodah
Have you tried running the spare wheel on that corner to see if there's an improvement? Confused I started with nothing and still have most of it left!
Post #439247 21st Jul 2015 7:37am
67_6Cyl
France
Yes, and no.
Jon
Post #439254 21st Jul 2015 8:03am
jst
i dont think ARB bushes will cause uneven tyre wear, knocking yes. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #439415 21st Jul 2015 7:38pm
