Home > Maintenance & Modifications > Fault finding rear axle, help please |
67_6Cyl Member Since: 10 Feb 2010 Location: France Posts: 97 |
Hi all......
Defender 110 CSW 2007 Puma TD4 Problem: Generally a crappy ride, and vibration at 110 km/h - no clear cause for this, but appears to be more from the rear axle, and the axle is noisy. Now, over the last 2 weeks there has started to be an excessive tyre wear on the (UK) O/S rear tyre. It is a band at the outside of the tyre, that goes all the way round. Where should I start troubleshooting, bushes? Wheel bearings? Or the rear differential? Thanks, Jon |
19th Jul 2015 2:42pm |
Just spent 2 hours under the car.
The wheel bearings feel fine, and there isn't abnormal play in the diff. However, both panhard rod bushes and the trailing arm (where it joins the chassis) look very sad. New bushes will be bought tomorrow. Jon |
19th Jul 2015 6:14pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7961 |
how many miles
vibration likely to be prop balance and or UJs need doing. tyres wear, pressures, bushes or alignment issue. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
19th Jul 2015 10:05pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20235 |
How long are UJ's supposed to have life expectancy wise?
19th Jul 2015 10:44pm |
200,000 kms......
Props are ok. They were done last year, and I couldn't find any play in the UJs. The tyres are worn, but balanced about 9 months ago, and pressures are correct (trailair monitor). HTH Jon |
20th Jul 2015 6:09am |
Does it stop in a straight line?
For tyre wear to develop nd be noticeable in two weeks it would be something noticeable I would of thought. Has vibration started at same time? Props may if been done last year but doesn't mean uj hasn't gone or bal weight come off, no best in them or play checked when off? Or stiff, ie new uj not settled right? Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
20th Jul 2015 7:15am |
Yes it stops in a straight line. - propshafts off yesterday, the weights are on, in v good condition generally, UJ's not "stiff", but OK.
After looking yesterday, and tightening up the saddest of the Panhard rod bushes she was much better this morning, much quieter, and far less vibration - it was noticeable how sad the bush was, I was able to tighten the bolt by about 2mm........ I'll go with new panhard rod bushes, and then I'll do the trailing arm bushes. Best Jon Actually, on the rear it's a sway arm , anti roll bar, or something isn't it? |
20th Jul 2015 8:33am |
vibration is more likely to be something rotational in my experience if it occurs at a certain speed and is more than a rattle. Cheers
20th Jul 2015 9:02pm |
I suspect that I actually have multiple things making noise / vibration.
The first to attack was the rear as there is clear uneven tyre wear. As said at the start of the thread this is quite probably linked to axle location. Having changed the anti roll bar bushes last night the beast is much improved and I have removed several bad points, and I hope that tyre wear will become normal. Over the next couple of weeks I'll try and nail down the other vibrations one by one, but having tested everything rotational, either I am a useless tester, or it's not an immediately obvious problem. The only thing that I haven't been able to test is the transfer box...... |
21st Jul 2015 6:50am |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2071 |
Stupid question.....(there's no such thing is there?).....
How/where do you get the props balanced? On or off car? I'll get my coat..... |
21st Jul 2015 7:37am |
it needs a special machine.
I went to a local HGV garage, and they did it for a very reasonable fee. Jon |
21st Jul 2015 8:31am |
Rickydodah Member Since: 14 Jul 2014 Location: East Sussex Posts: 1091 |
Have you tried running the spare wheel on that corner to see if there's an improvement? I started with nothing and still have most of it left!
21st Jul 2015 8:37am |
Yes, and no.
Jon |
21st Jul 2015 9:03am |
i dont think ARB bushes will cause uneven tyre wear, knocking yes. Cheers
21st Jul 2015 8:38pm |
