Home > My Defender > My new (to me) Defender 90 Puma |
fathaggis Member Since: 31 May 2015 Location: taynuilt Posts: 385 |
both look great ..... as for the clay and polishing i did it to regularly the car i sold to get BEASTIE . the paint on the 90 is near new but i give a it a good polish and waxing here is the car i sold to get my defender
Click image to enlarge and the 90 that replaced it ...... Click image to enlarge |
12th Sep 2015 12:00pm |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2025 |
Took the bonnet off today to fix down the centre chequer plate panel with black pop rivets.
Photos of progress. Also took the opportunity to put some self adhesive sound deadening on the underside. Sorry they are not in order but doing this on an iPhone. Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
12th Sep 2015 6:25pm |
NJS22 Member Since: 26 Oct 2012 Location: Cornwall Posts: 169 |
Don't know how you had the nerve to drill the bonnet, well done mate 1998 90 50th Anniversary 4.0 V8
2016 90 Adventure 2015 Range Rover Sport 1971 Range Rover 2 Door Wife won't let me have any more...!!! |
12th Sep 2015 6:35pm |
Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514 |
Great Job !!!
Marco Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
12th Sep 2015 7:02pm |
13th Sep 2015 9:18am |
Did my ritualistic Rain-X on the glass work today, makes SUCH a difference. 2016 D4 HSE
13th Sep 2015 4:33pm |
A bit of a tip for the drilling and riveting.
I lay the plate on the bonnet with a cloth underneath to stop it moving, centred it and then marked the holes with a centre punch just enough for me to see them once the plate was removed. Then I drilled a pilot with a 3mm drill, not all the way through but to hold the head of the larger drill and stop it skidding (some people use a piece of insulation tape). Then I drilled the front set of holes with the 5mm drill and double checked my marks were all still correct when I placed the rivets into the holes. The bonnet is double skinned so most holes have to be drilled through both layers to allow the rivet to sit flush. ( I guess you could get away with a shorter shank rivet) Once all the holes were drilled I placed all the rivets through, ready for the final part. One or two just needed the drill passing through the plate and bonnet as the plate itself had a minor discrepancy in the pre drilled hole. Then using my lazy tong rivet gun and with a piece or cardboard to protect paintwork from bouncing or slipping I slowly pulled the rivets. Each one took 5 strokes as they had a long shank. The lazy tong doesn't pop and bounce as much as hand held guns but I held it firmly in my left left right at the bonnet surface to ensure it didn't move. No mishaps and all done. An easy job anyone can do, just take your time and don't rush. 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
14th Sep 2015 7:19am |
Snowy90 Member Since: 23 Feb 2015 Location: Surrey Posts: 482 |
Lovely looking 90 and great job on the bonnet chequer plate. What sound proofing is that underneath? Does it make much of a difference?
Great thread by the way. |
14th Sep 2015 9:29am |
Thanks for the compliment.
The sound proofing was some I had left over from doing my last TD5. I bought it on eBay to line the entire car. It's very thick, about 12mm, is self adhesive and has the silver heat reflective layer. I joined strips with aluminium tape to neaten it up. If you want to see that work you'll need to find my other defender thread in the My Defender section. Every little bit helps with reducing panel resonance and boom, one piece alone won't make a huge difference. I used it cos I had it to hand. 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
14th Sep 2015 11:52am |
This is a link to the type of sound deadening material I used, this is one being sold by Powerful UK
http://www.ebay.co.uk/itm/Self-Adhesive-so...58a0fe679f 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
17th Sep 2015 2:59pm |
Thanks for the link, seems cheap way of getting it a little bit quieter!
Mine is now soundproofed on the floor panels and bulkhead etc... So maybe time to continue the sound proofing journey! |
18th Sep 2015 8:51am |
Went to the LRO show today and had a small shopping list. The one thing I really wanted was the rear loadspace rubber mat but they are £115 and apparently don't quite fit the floor pan of a CSW with the seats removed.
So, plan B. I bought a roll of chequer plate design rubber mat and cut it to fit myself. Price was £30. Will work a treat. Took a panoramic photo but it looks odd. It's better in the flesh. Very pleased. 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
20th Sep 2015 9:01pm |
[deleted] 2016 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol Last edited by RRUK on 20th Sep 2015 9:46pm. Edited 1 time in total |
20th Sep 2015 9:42pm |
20th Sep 2015 9:43pm |
