Home > My Defender > My new (to me) Defender 90 Puma
Page 9 of 34 <123 ... 8910 ... 323334>
RRUK
Decided to attack the rear badge situation in a coffee break this morning.
The original green oval and Defender sticker were looking very tired and ruining my grey and black theme, so at the LRO show I bought one of the 3D gloss black Defender badges. I didn't see any black and silver ovals so will get one on eBay.
After using the toffee wheel to remove both (no point trying to pick off the sticker), cleaning it up with petrol, then compound, polish and wax, I had a bare clean canvas to work on.
The end result looks much nicer.
 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #457063 22nd Sep 2015 10:26am
RRUK
A present arrived first thing Very Happy
My spare sawtooth and new BFG AT KO2 pattern tyre.
Looks nicely aggressive on the sidewall compared to the old version. Not sure if I want the White lettering showing yet.
Trouble is, I like the look of these so much I want a full set! Big Cry
 2016 D4 HSE
Post #457382 23rd Sep 2015 8:38am
AndyTunn
New Zealand 2008 Defender 90 Puma 2.4 SW Stornoway Grey
That does look rugged - I can see why you want a full set! What size tyre is that? It looks different to the one on the car but that could just be the photo of course.
Post #457385 23rd Sep 2015 8:53am
RRUK
Its just the perspective as it's sitting in front of the car.
They are all 265/75/16 2016 D4 HSE
Post #457390 23rd Sep 2015 9:08am
YOLO110
Australia
That sidewall is now virtually all tread! No wonder it looks so big!
Cool too... Cool
I can see why you love them.
Personally, I prefer the practical 'quiet running' of the Continental Cross A/T... even with 50:50 on:off road Thumbs Up YOLO... You Only Live Once...
Post #457397 23rd Sep 2015 9:11am
fathaggis
tyre looks great Thumbs Up get the set Mr. Green
Post #457401 23rd Sep 2015 9:23am
Cake
Your car looks fantastic, I remember seeing it when you first got it and was very jealous as I was in the market too at the time (only just got mine!).
Were the sawtooths a straight swap for the boosts tyres? I remember seeing it somewhere but but search isn't helping.
Also with the rear badge don't new ones fit inside te plastic capping? Make sure you keep hold of it!
Post #457545 23rd Sep 2015 4:46pm
RRUK
Another present in the post.
As I want to have my spare sawtooth and new BFG AT KO2 on the back door I want to prevent it being pinched.
So, it's going to have 3 Locking wheel nuts and this lovely lock.
 2016 D4 HSE
Post #458162 26th Sep 2015 10:15am
RRUK
Well I had my new set of locking wheel nuts arrive. These will be used in place of standard nuts for the spare wheel as it seems it can't be secure enough. I'm going to put all three on, plus the new lock above.
The new 2015MY oval badge is nice, I wanted black and silver and ordered this by mistake but oddly it was half the price. He background colour is a dark metallic green and looks nicer than the stock oval.
My rear end is looking much nicer! Whistle 2016 D4 HSE
Post #459437 1st Oct 2015 6:00am
RRUK
Time for Dinitrol!
OK, this is not a quick job to do, I spent an entire weekend doing it (not inc the prep) and having done it with Waxoyl on my TD5 I knew some of the pain I'd have to endure. This time I wanted to do it properly. Timing was crucial. I had pressure washed every nook and cranny, flushed it out and air blasted all the chassis and it had been able to dry thoroughly for 2 weeks. We had a dry weekend so I knew it was time to get on with it.
Here's the kit I bought to do it:
Dinitrol kit from Rejel (compressor version)
A can of ACF-50
throwaway coveralls x 2
disposable latex gloves
full face protection
Breathing masks
shower cap (you don't want this stuff in your hair)
You'll also need:
4 x Axle stands - I bought another pair of 3 tonne ones from Halfords for £17.50 and they're great
A tarp and/or plastic sheeting (I had an old tarp and also put thick polythene from a mattress that was delivered)
plastic bags
Tin foil
Masking tape
Masking paper
Paper towels
White spritis
A decent jack
A compressor (I got mine from Aldi)
So, here's how to do it at home (and apologies to Zag as I'm sure you do a much more thorough job).
First I removed the wheels and jacked it onto the axle stands after laying out the plastic sheeting - TRUST ME - you will need this.
Once up in the air I crawled underneath and poked around with a screwdriver and low and behold, found even MORE dried mud up inside the door pillar area, so cleaned this out. I half filled a bucket with all the rubbish I got out of it again. More blowing out with the air gun.
Whilst the wheels were off I turned the steering full lock each way so that I could take the opportunity to top up the swivels with one shot grease. Surprisingly each one took three quarters of a pouch. It's an easy job with a 1/2" socket. I advise you to check yours.
Here you can see the filler plug in plain view.
Next I started masking the car up. I didn't do this last time, but having watched a video on Youtube on how the Pro's do it, I decided to give it a whirl and am VERY thankful I did. I put masking paper along the paintwork and also wrapped the axle stands, brake discs, flexible brake pipes, exhaust system and side steps. I am so pleased I made this effort.
First I sprayed any signs of surface rust with the rust converter spray in the kit. The fine mist of the Dinitrol cavity wax gets everywhere, so the masking was worth it. The instructions say to prime the outer chassis with this stuff first as it aids adhesion. You obviously also use this to spray inside the chassis box sections etc. I used the extension tube to get inside the bulkhead via the blanked wiper holes, door top hinges and the door switch hole inside the cabin, until it was dripping out of all the places you'd expect it to.
Whilst the top hinges were undone I also ACF'd the captive nuts (which looked like new) and replaced the bolts with stainless steel ones (also sprayed in ACF50).
Once the chassis is primed, you can apply the under chassis wax whilst still wet. This stuff needs 6PSI to spray properly and is nice and thick when it goes on, I coated everywhere in it, especially the areas that are prone to corrosion such as footwells, outriggers, rear X member etc. Axles also got a nice coating but steered clear of the propshaft to avoid balance issues.
After doing the wax, I then used the stone chip on the wheel arch areas. The instructions say not to spray the stone chip over the wax or vice versa (so I didn't). In the front wheel arches there are numerous holes in the plastic moulding, so I blanked these in with aluminium tape prior to spraying, to avoid lots of overspray in the engine bay.
I won't detail every single part and step I went through, but let's just say I was extremely thorough.
The end results looks good and it doesn't stink like Waxoyl.
Top Tips:
You cannot prepare enough - it seems a pain but is SO worth it.
The more protection you wear the better, you will get filthy, throw away coveralls, gloves etc are going to save your workshop gear. The full face visor I got from Toolstation was great, as it doesn't fog up like goggles.
The tarp on its own would have been useless as they have a weave, try calling a local bed supplier and asking if they have any mattress covers, the thickness is perfect.
Put the axles stand inside a plastic bag or bin bag before setting them under the car, or they get waxed.
Wrap the exhaust in foil front to back, its easy to do and effective, easy to remove.
It's an easy enough job to do yourself at home on the driveway, but you need to do your prep work. The end result though is the personal satisfaction and peace of mind that the underside is fully protected for years and years to come.
Shame no one else gets to see the end result! Big Cry 2016 D4 HSE
Post #460475 4th Oct 2015 7:59pm
fathaggis
great stuff .... when do you want me to drop mine off for the same treatment Whistle Mr. Green
Post #460500 4th Oct 2015 9:15pm
Pickles
RRUK, TOP job on your undercarriage mate, and especially with your preparation/masking, and,.......doing it in the open. Obviously you were lucky with the weather.
Very methodical, Pickles.
Post #460506 4th Oct 2015 9:26pm
RRUK
Thanks Pickles, I like to be thorough and pay attention to the detail, I've never been a bodge-it merchant. Thumbs Up 2016 D4 HSE
Post #460912 6th Oct 2015 8:34am
steve E
Wales
Really enjoyable thread.
Love your eye for detail.
Impressive stuff Thumbs Up
Post #460916 6th Oct 2015 8:49am
Stacey007
That really looks great,
It just would worry be being under the LR with 4 axel stands..
when we used to do this with old mini's we used a friends 'pit'
roughly in bits how much would this cost to do? assuming I have the use of a compressor?
Thanks it looks great !!!
Post #460943 6th Oct 2015 12:52pm
