Home > Technical > hi lo revs switch |
one thing I hadn't realised until recently about the idle jack (which is the feature you're talking about) is that it doesn't have a switch telling the ECU you're in 1st or reverse. It just guesses you are based on the engine revs and forward speed.
11th Jun 2015 11:29am |
Exactly, which is the recently I was referring to
Just thought I'd pass that on |
12th Jun 2015 1:18pm |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6312 |
tightened the earth on the battery the other day and all seemed good but now
rev counter is waving up /down. not a lot but clearly it's not right. also getting the clatter sound which I'm assuming is the result of a poor electrical signal but why o why o why ? |
17th Jun 2015 9:59am |
Just tried the hi/lo again after removing the plug on the side of the transfer box (not sure if it was hi/lo or diff lock).... Anyhow tried the hi/lo and in low in 1st no increase in revs while clutch depressed.......and slowly released....and then increased for a bit fluttered about and then went again and can't get them to increase again eight in first or reverse?
Any ideas? |
19th Jun 2015 9:08pm |
I think what I unplugged because was the speed sender - but not sure?
Is the hi/lo switch accessed from above ie cubby box out? |
20th Jun 2015 6:04pm |
The speed sender is behind handbrake drum down the bottom
20th Jun 2015 6:07pm |
Thanks Munch90 - so it was the speedo.
Need to get to the top I presume for the hi/lo? Cheers mate. |
20th Jun 2015 7:10pm |
Might be worth checking one of your posts , check your rods or something , think it may be the one in your own pic
sorry dont know 100% , as never played with switch |
20th Jun 2015 7:27pm |
Hmm good thinking...
I think the link rod changes position of get lever and doesn't impact on the switch ( but not sure) |
20th Jun 2015 7:39pm |
Yes , but in the pic , you can see a switch
20th Jun 2015 7:42pm |
eBay Item No. 111646389017
Hi lo switch |
20th Jun 2015 7:45pm |
Thanks Munch90. Will go have a look shortly.
20th Jun 2015 7:55pm |
pumaxs Member Since: 18 Jul 2012 Location: Bath Posts: 180 |
That's interesting. I drive the 'Spaniel Taxi' in low range on a daily basis. On mine, the revs do not pick up as soon as either low 1st or reverse is selected. Having released the clutch, with no throttle input, revs have picked up to just over 1k rpm after travelling approximately 5 or 6 feet. Not an exact measurement - I just lined the front mud flap up with a dandelion Am I normal? '57 Defender 110 XS Station Wagon 2.4tdci |
20th Jun 2015 11:15pm |
hi/lo switch now disconnected, so will see how it goes later?
21st Jun 2015 9:58am |
