![]() | Home > Technical > Q421- Oil Pump Failure **JLR RECALL** |
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1330 ![]() ![]() ![]() |
If my dealer told me they were going to re-use the old oil, I would have told them not to start the job and I'd have booked it in at a different dealer. Unless of course they were going to chuck the old oil in a workshop space heater or something similar.
I can't imagine for one second the LR recall sheet instructs them to use the old oil. |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3787 ![]() ![]() ![]() |
Gracie was "done" last week, along with her B service, all very opportune, didn't have to pay for oil & filter.
Pickles. |
forest172 Member Since: 01 Nov 2012 Location: derbyshire Posts: 355 ![]() ![]() |
well the oil appears golden in colour. I can`t see that being the old oil from October last year and 5k
Sounds as though all is well forest172.
Rugerrog Member Since: 16 Jan 2015 Location: Derbyshire Posts: 12 ![]() ![]() ![]() |
Well here we go again had a call from the dealers my 14 plate 110 has got to go in for, wait for it oil pump recall !!!!! I thought this would have been sorted by now. time for some free oil, new pump and sump booked in and waiting
![]() with a straight 6 petrol engine ![]() |
Greadh Member Since: 17 Feb 2016 Location: North West Posts: 97 ![]() ![]() ![]() |
Hi. Recently got a 2 year old 110 utility within vin range from a main deal, is there an easy way to check the recall has been addressed? Being from a main dealer you'd hope, but best to check
![]() Going to look under tomorrow, see if sump looks newish, but is low milage so might not be that obvious. |
Best to check with your dealer, they can check the system & give you certainty.
Pickles. |
Will do thanks. Just wasnt sure if there was a part number viasable that would show it's been done. But as you say, best get direct from them to be sure.
PRENT1 Member Since: 02 Sep 2015 Location: bromley Posts: 42 ![]() ![]() ![]() |
Just called my dealer, and asked them to check if my car was due the recall they said yes... when i asked why they did not carry it out whilst it was in their garage they said 'because i never asked....?'
I recommend that if you have a 2.2 just phone your dealer and quote Q$"! recall and they have to check. |
No need to call dealer just register on Topix with your VIN and it will show whether there are any outstanding service actions.
Thanks, Topix = No Outstanding Field Service Actions - so I presume it was done by previous owner/deal before I purchased
Dobby Member Since: 23 May 2012 Location: East Seaxe Posts: 187 ![]() |
Do we know if TOPIx will show the campaign even if it's expired? I'm wondering if TOPIx now doesn't show the Q421 campaign as it's ended, so when you login and check your VIN it appears as though the work is not needed, whereas it actually is?
It should still show it, it has all the TSB's on there.
unless i'm looking in the wrong place, I don't think so. I see this on the home page. But local dealers can't tell me if the work has been completed already, or not. They just say it's not needed and that not all VINs in the range are affected.
![]() Click image to enlarge
