Home > Puma (Tdci) > SVX lights |
Yes they fit TD5 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
28th Jun 2010 8:04am |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
I'd fit 70mm LED's
28th Jun 2010 8:21am |
Me too Ken Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
28th Jun 2010 9:21am |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 809 |
A front end conversion is about £900 + vat (give or take a bit), I happen to have one for my Defender It will bolt straight on without a problem, but you need to ensure you order all of the correct brackets. The lighting kit also comes with all of the required loom. Rear lights... Two choices genuine spec SVX lamps (don't buy from LR though, unless you want to spend £££££'s) - I can supply full kits, with everything to do a complete conversion. PM me for a price. Or the excellent Mobile Centre LED 70mm lamps - which I can also supply and fit if needed (see next months LRM ). Tim (Mr Mobile Centre) - after much nagging on my part - is sorting out clear lens versions of the indicators and stop/tail. Interestingly, I can also fit a 70mm Mobile Centre LED indicator lamp to the SVX front end if required. Ian |
28th Jun 2010 11:15am |
I think we are speacking about only the headlamp not the all front grill Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
28th Jun 2010 11:40am |
I'm going to try the 8700s in the SVX surrounds ... waiting to see what happens to the price and / exchange rates, £1500,00 is a lot of ££
28th Jun 2010 5:24pm |
