Home > Puma (Tdci) > SVX lights
g1bvi
SVX Lights
Hi there
Thinking about adding the SVX Lights to my Landy
Will the new front lights fit a TD5
Wonder how much a whole set of lights might cost
Thanks in advance
Nick
Post #35206 27th Jun 2010 9:57pm
dgardel
Italy
Yes they fit TD5 Thumbs Up Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #35224 28th Jun 2010 8:04am
I'd fit 70mm LED's
Post #35226 28th Jun 2010 8:21am
dgardel
Italy
ken wrote:
I'd fit 70mm LED's
Me too Ken Mr. Green Mr. Green Whistle Whistle Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #35230 28th Jun 2010 9:21am
Porny
Site Sponsor
Re: SVX Lights
g1bvi wrote:
Hi there
Thanks in advance
Nick
A front end conversion is about £900 + vat (give or take a bit), I happen to have one for my Defender Wink
It will bolt straight on without a problem, but you need to ensure you order all of the correct brackets. The lighting kit also comes with all of the required loom.
Rear lights...
Two choices genuine spec SVX lamps (don't buy from LR though, unless you want to spend £££££'s) - I can supply full kits, with everything to do a complete conversion. PM me for a price.
Or the excellent Mobile Centre LED 70mm lamps - which I can also supply and fit if needed (see next months LRM Whistle ). Tim (Mr Mobile Centre) - after much nagging on my part - is sorting out clear lens versions of the indicators and stop/tail.
Interestingly, I can also fit a 70mm Mobile Centre LED indicator lamp to the SVX front end if required.
Ian
Post #35242 28th Jun 2010 11:15am
dgardel
Italy
I think we are speacking about only the headlamp not the all front grill Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #35248 28th Jun 2010 11:40am
I'm going to try the 8700s in the SVX surrounds ... waiting to see what happens to the price and / exchange rates, £1500,00 is a lot of ££
Post #35267 28th Jun 2010 5:24pm
