Home > Land Rover Customer Relations > EKA Code
Page 5 of 5 <12345
spudfan
Ireland
Would it be too simplistic an answer to say put a fresh battery in the key fob?
If you need access to the interior of the vehicle you can push in the quarter light (small window to you and me) on the left hand side of the rear door. Once you have done this you should be able to insert your arm and manually open the rear door. I think there is a video up on this site showing how to put the window in. Just put pressure on it close to the rubber seal. Give it a quick shot with the palm of your hand or use a cloth, a piece of wood and a hammer. The window should not break. The hard part is getting it back into place again. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #839767 26th Jun 2020 12:29am
SergeantJav
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Corris Grey
I can get in and out....I have a key...yes I changed the battery....I now have a failed visit by Greenflag and an auto locksmith who couldn’t get his diagnostic machine to speak to the ECU for the security system...but the Landy showed no faults... I have also tried the reset resync sequence on other posts...nothing seems to work. So I have a very expensive Corgi toy on my drive Sad
The issue is the immobiliser has kicked in and no-one van give me the EKA code... it’s a 2015 Puma if anyone else has any ideas... the main dealer couldn’t suggest anything... Crying or Very sad
I am not even convinced the EKA code will work...
Anyone at land rover head office not furloughed read these posts ? Proud to own 110XS TDCi SW..previously 90XS Td5 SW
Post #839769 26th Jun 2020 12:53am
I have a suspicion that a 2015 Defender will have the non-Lucas 10AS that was fitted to the production runout vehicles and I don't think that these units even have an EKA code (the genuine Lucas ones all do even though the dealer network and JLR deny this). I'm sure by now you've tried the usual things like repeated presses of the fob buttons to resynch?
Post #839788 26th Jun 2020 8:46am
SergeantJav
Yep...tried the usual from other posts...plus the auto locksmith tried his diag software but couldn’t access the module... Big Cry
I think you might be correct and this could be a ticking time bomb for a lot of late defender owners... Crying or Very sad Proud to own 110XS TDCi SW..previously 90XS Td5 SW
Post #839792 26th Jun 2020 9:04am
If all else fails, get in touch with Pete Bell at BAS (search the forum or google for contact details) since I know that he can offer a solution which renders the 10AS completely redundant.
Post #839798 26th Jun 2020 9:21am
SergeantJav
Will try the main dealer again...but will bear in mind... Proud to own 110XS TDCi SW..previously 90XS Td5 SW
Post #839805 26th Jun 2020 9:43am
SergeantJav
Looks like the late defenders do indeed not have a code... my fault turned out to be a blown fuse...stopped the ECU for the alarm/immobiliser from talking to anything or responding hence no lock/unlock and wouldn’t let engine start... well worth a look if yours does similar.... break down truck had picked a few up that had same symptoms ....finally diagnosed by the main dealer...not sure why fuse blew....20amp Confused Located in main fuse box below steering wheel Neutral Proud to own 110XS TDCi SW..previously 90XS Td5 SW
Post #842366 7th Jul 2020 5:48pm
s55shh
someone a couple of pages back got an EKA code for a 2016 model year 90.
Post #851708 24th Aug 2020 2:54pm
Giles Dixon
United Kingdom 2013 Defender 90 Puma 2.2 HT Santorini Black
EKA code
I have just successfully obtained the EKA code for my 2013 defender from Landrover Customer Assistance 0370 5000500. You will need to email copies of the first two pages of the log book. They will then email the code back to you.
Post #985663 15th Mar 2023 7:33pm
miker916
Scotland 2005 Defender 90 Td5 HT Belize Green
The later non-LUCAS 10AS Defenders do still have an EKA. I was able to get mine using my GAP IID tool with a specific firmware
Post #990700 28th Apr 2023 1:08pm
RedRooster
France 2014 Defender 90 Puma 2.2 SW Corris Grey
I've done the same changed the fob battery out of the car, now it won't start and no code in the dealer paperwork pack.
Post #1008706 24th Sep 2023 6:19pm
Ianh
Have you tried to resync the fob.
Open drivers window, shut all doors.
From outside vehicle press the lock button four times in quick succession.
Then press the unlock button and the doors should unlock.
Now try to start the vehicle with the fob attached to the key
Post #1008718 24th Sep 2023 8:01pm
Page 5 of 5 <12345
