![]() | Home > Puma (Tdci) > help have i got the wrong stat |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
change the traditional stat. its in the block for a reason. the other one it to speed up the heating of the heater...
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5868 ![]() ![]() |
It always ways does turn out harder than it should be.
Please do a report on your findings
never seen a engine with two thermostats |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2774 ![]() ![]() |
Sorry didn't read the whole thread above (out) but it's the plastic housed thermostat that I replaced & sorted my problem. It wasn't opening in warm water when I tested it.
This is the one I bought http://m.ebay.co.uk/itm/331132538262?_mwBanner=1 Replied to your Pm too Bear100 ![]() Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
Thats the one
munch90 is right
only the external (plastic housing) thermostat Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
nickhodgson Member Since: 08 Dec 2009 Location: Zambia Posts: 174 ![]() ![]() |
The plastic one is the Puma one the other one looks like a 300tdi thermostat. The part number for the Puma thermostat (the plastic one in the earlier pictures) is the same as for a TD5 so its a part that has been used for a while. What is the problem? 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C 2000 300tdi Defender 110 P/UP 2015 Discovery 4 SDV6 HSE |
Thank you |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1986 ![]() ![]() ![]() |
![]() Has anybody ever looked or changed the water pump? According to the manual there is one there?? Still just as confused ![]() 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
not in my manual there isn't , no mention of a thermostat near the pump
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 ![]() ![]() ![]() |
Just to throw a spanner in.......
Isn't there the normal (plastic y-shaped one) thermostat which controls the water bypass for the heating circuit, but also another thermostat which controls the flow through to the oil cooler? Or is this integral to the oil cooler? To quote the workshop manual; "The engine cooling system cools the oil in the oil cooler and is regulated by means of a separate thermostat, which prevents the flow of coolant through the oil cooler when the engine is cold, ensuring the engine oil warms up quickly. The thermostat opens at 75�2�C (167�35�F)." Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
the oil cooler thermostat is in the little plastic pipe the joins to the oil cooler on the filter housing
and before anyone says it must be the top one in the first post picture , no it isn't , the cooler one is very small comes as part of the pipe is held in with one bolt and has a o ring to seal it there is also a thermostat for the fuel and yes its not that one either ![]() |
....but to answer the "which one is causing overheating".
If the ickle-micro-thermostats are not working then; Oil cooler not cooling and/or fuel cooler not cooling could help towards engine getting hot. However, I'd be more inclined to say it was the plastic jobby. With the ones fitted to the Transit missing, I assume that the plastic one has been introduced due to the fact that the water has to flow to non-transit stuff. Therefore, the redesign took out the original Ford thermostat housing and replaced it with the well-known LR one. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
"plastic jobby" is the one that controls engine temp
yes remote plastic jobby replaces transit set up Last edited by munch90 on 19th Jan 2015 12:23pm. Edited 1 time in total |
