Home > Puma (Tdci) > Thought I would change
Dieselhead
Did the airbox mod today & what pain that was.
Any way, while I was in there Shocked I thought I would change my intercooler hose for a silicon one I had. Cool
Good job I did as the lower UJ on the PAS box had been rubbing on the pipe & was nearly through
Any way fitted the new pipe making sure it was not rubbing again
I wont be stuck at the side of the road now
Better check yours Thumbs Up Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
Post #377952 10th Dec 2014 9:46pm
taazzukcb
United Kingdom 2004 Defender 110 Td5 DCPU Stornoway Grey
Have you not had the 'fix' bracket fitted?
Post #378012 10th Dec 2014 11:24pm
Dieselhead
Quite clearly not Sad Chris
1983 Mini Mayfair
2004 VW T5 Camper
Post #378024 11th Dec 2014 5:23am
Cheshire110
Can someone give a lehmans description of how to locate the pipe in question please? Cheers, David
Post #378077 11th Dec 2014 10:37am
2008 model so out of warranty and not LRs concern maybe?
Could try and see if the parts dept would sell you the parts to save any potential damage to your new shiney hose?
Post #378084 11th Dec 2014 11:09am
http://www.defender2.net/forum/topic30113....ooler+pipe
Post #378085 11th Dec 2014 11:11am
willyj
United Kingdom 2011 Defender 110 Puma 2.4 USW Stornoway Grey
"Fix" bracket?
Is that a DIY one or landrover?
Ignore this post. Browser didnt reload new comments
Post #378086 11th Dec 2014 11:15am
Regard
South Africa 2011 Defender 110 Puma 2.4 X-Tech LE Orkney Grey
As far as I understand the "fix" bracket is only on the 2.2's and not the 2.4's.
Post #378101 11th Dec 2014 12:31pm
taazzukcb
Ahh yes ... it is only the 2.2 ... should of checked what you had. Just sort of assumed it was a newer 2.2 being the same sort of problem!
Sorry about that!
Post #378349 12th Dec 2014 10:28am
Are the ancillaries different on the 2.4 such that the bracket would not fit?
Post #378353 12th Dec 2014 10:39am
