![]() | Home > Puma (Tdci) > Thought I would change |
taazzukcb Member Since: 30 Aug 2013 Location: Derbyshire Posts: 663 ![]() ![]() ![]() |
Have you not had the 'fix' bracket fitted?
Dieselhead Member Since: 21 Oct 2012 Location: Pulborough. West Sussex Posts: 552 ![]() |
Quite clearly not
![]() 2008 XS 110 2.4 Utility. Tonga Green 1953 Series 1 for restoration 1983 Mini Mayfair 2004 VW T5 Camper 2008 Diahatsu Sirion. Thats hers Classic Bolens Garden Tractors |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2774 ![]() ![]() |
Can someone give a lehmans description of how to locate the pipe in question please? Cheers, David
Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
2008 model so out of warranty and not LRs concern maybe?
Could try and see if the parts dept would sell you the parts to save any potential damage to your new shiney hose? |
http://www.defender2.net/forum/topic30113....ooler+pipe |
willyj Member Since: 23 Oct 2009 Location: Carmarthenshire Posts: 197 ![]() ![]() ![]() |
"Fix" bracket?
Is that a DIY one or landrover? Ignore this post. Browser didnt reload new comments |
Regard Member Since: 08 Dec 2011 Location: RSA Posts: 251 ![]() ![]() ![]() |
As far as I understand the "fix" bracket is only on the 2.2's and not the 2.4's.
Ahh yes ... it is only the 2.2 ... should of checked what you had. Just sort of assumed it was a newer 2.2 being the same sort of problem!
Sorry about that! |
Are the ancillaries different on the 2.4 such that the bracket would not fit?
