Home > Puma (Tdci) > MY2011/2012 Recall Action P047/048 Front Axle Case
Page 35 of 39 <123 ... 343536 373839>
Dinnu
blackwolf wrote:
I think you mean 300Tdi to 1999 in your second point, not 2009. Thumbs Up
Thanks for the correction. Surely I was not thinking about the MODs 300s 😂 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1023616 5th Feb 2024 5:03am
LR90XS2011
well I took my Defender for the recall today and other than the courtesy car not materialising (which to be fair they told me on Friday as apparently it came back damaged) and spending 4 hours in their lounge area rather than the 2 I was told it would take the job to get done.
I got my already fitted brackets back despite again being told they had got to go back to JLR, I think the note I left for the Service team on the seat probably worked better than all the conversations I had with the various representatives in office attire.
Hopefully the recall has been closed on the system
Sytner Coventry if anyone wants to take theirs to someone whom will do it.
Ianh you have a PM
Now I just need to start collecting bits for the axle case swap which will be the only way to get real piece of mind. DEFENDER 90 TDCI XS,
Post #1023653 5th Feb 2024 3:47pm
spudfan
Ireland
Success of sorts so well done. Imagine celebrating the fact that you actually got a maindealer to do what they were supposed to do! Also getting your own property left to you when the job was done seems to be another cause for celebration! Either we are a strange inconsiderate bunch who would expect these courses of action to be the norm or we live in strange times! 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #1023657 5th Feb 2024 4:01pm
TexasRover
Ok, so you had the brackets fitted, but to close out the recall they had to remove those and fit a new set, then the removed brackets had to go back to LR, but instead they gave them back to you?
Makes you wonder what idiot comes up with all this logic, obviously no bearing on the real world.
I have given up on garages for anything other than tire changes and such. The time it takes to organise the visit and then wait or come back etc, I just do most my self. Obviously I recognize it took me years and years to build up the toolset and experience and obviously I like doing it as well. Just seems using a garage is so such hard work.
Post #1023658 5th Feb 2024 4:04pm
LR90XS2011
Indeed I am finding I now expect poor service as it appears to be the norm in all walks of life, needed them to do it as it was the only way they would close the recall DEFENDER 90 TDCI XS,
Post #1023659 5th Feb 2024 4:06pm
Dinnu
Is this JLR or a Faulty Towers episode Laughing
I think giving back to the owner is correct, because the brackets were not JLRs property. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1023660 5th Feb 2024 4:14pm
TexasRover
Yes for sure, I forgot to add that juicy fact. There have got to be people within these companies shaking their heads, but they are probably paid less so not important enough..
Post #1023661 5th Feb 2024 4:20pm
LR90XS2011
Gratuitous photo of it waiting attention
[/img] DEFENDER 90 TDCI XS,
Post #1023663 5th Feb 2024 4:24pm
Ianh
That is one pristine defender Thumbs Up
Glad it all got sorted in the end, but what a rigmarole to get them to , 1 do the work, 2. Give you back your own property.
And just sent pm back re still wanting brackets, i’m Just a couple of days and few hundred vehicles beyond the recall notice, but knowing JLR records are far from accurate (understatement) and I don’t trust them either given their attitude to this whole issue, then I want to fit to give me a bit more of a chance if my axle fails.
It certainly won’t take four hours to fit them both Very Happy
Ps. On your front bumper what are the 2 recesses between the soft A Bar uprights for ? I’m assuming some sort of lights ?
Post #1023669 5th Feb 2024 5:35pm
LR90XS2011 wrote:
... spending 4 hours in their lounge area rather than the 2 I was told ...
...I got my already fitted brackets back despite again being told they had got to go back to JLR..
I'm not sure why a job timed at 12 minutes took 4 hours, unless it took 3 hours and 48 minutes to free your old brackets after the nuts were removed!
Failing to return your brackets would have been a crime (theft by conversion) and I seriously doubt that the recall says anything about returning them the LR. If you were having a broken axle replaced (or indeed any other faulty parts replaced under warranty) that would be expected, but not in this situation.
What a hassle, eh?
At least it wasn't that shower in Derby, they'd probably have written the vehicle off and told you to claim on your own insurance!
Post #1023695 5th Feb 2024 7:48pm
LR90XS2011
Nakatanenga light bezzles with ring driving lights. however they are redundant now the light bar is fitted and the bumper has started to go rusty so I have a very reasonably priced stainless one on order without the holes[img]
Post #1023699 5th Feb 2024 8:18pm
Oldowner
This 2012 90 belonging to a friend suffered axle casing failure today, apparently felt like a flat tyre for a split second before completely letting go and slewing across the road, hitting a wall - note trackrod!! Unsure if he had receive a recall notice for it or not.
Post #1023792 6th Feb 2024 8:27pm
Dinnu
Hope driver and occupants are ok and no one injured.
As I stated in earlier posts, its not if it happens, but when. Every component has a service life, the higher the stress, the lower the life.
Do you have access to the Defender and could snap some close up pictures of the weld? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1023793 6th Feb 2024 8:50pm
Oldowner
Yes, I have the Defender at my workshop, I have a spare 2008 casing to go on it, I’ll take some detailed photos once I’ve removed the axle
Post #1023796 6th Feb 2024 9:40pm
LR90XS2011
Yes I expect now they are getting older we will see more failing DEFENDER 90 TDCI XS,
Post #1023797 6th Feb 2024 9:47pm
