![]() | Home > Wheels & Tyres > 285 |
LR09WA Member Since: 30 Apr 2009 Location: Perth Posts: 88 ![]() ![]() ![]() |
So if I fit 285/75/16 on the boost rims with spacers, what are the down falls..... I want to set the car up to do a lot of boat towing on sand so I am keen to increase my tyre foot print, without effecting roadability to much....
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 ![]() ![]() ![]() |
I ran 285 BFG MT`s on Boosts with spacers for over 2 years and no problems
Thanks Mate... what spacers did you fit... |
Sonic did you find much change in the roadability of the car, heavy steering, bump steer, vague steering or anything of the like...
I had 40mm spacers from Rakeway Engineering
Thanks
PDH Member Since: 03 Dec 2009 Location: Shropshire Posts: 179 ![]() ![]() ![]() |
Im running 285's on boosts with 30mm spacers and no issues at all 20000 miles done so far and not an issue other than dirtier than normal car lol Puma 2.2 90 Stationwagon
Cibit Member Since: 26 Oct 2009 Location: Northumberland Posts: 424 ![]() ![]() ![]() |
Don't decrease your tyre pressures with 285's on 7" rims or the bead may pop ![]() 55 TD5 110 CSW Special Vehicle |
Be intersted to know what you're basing your opinion on as my Coopers due to their profile on-road (and wear pattern) appear to have less road-contact than the standard grabbers had??? ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
CFB Member Since: 13 Sep 2007 Location: Bradford, West Yorkshire Posts: 803 ![]() ![]() |
It's to do with the wheel off-set, the further out from normal, the higher the strain on wheel bearings etc. Andy
So it's offset which is more significant than width which affects bearing wear then? At between a paltry £14:99 to £20:50 for a bearing kit dependant where you buy I don't think I'll be rushing out to rip my 10Js off my vehicle and refit the ice-cream van ones? I think I'll take my chance on having to change them sometime, the bearings that is!
![]() ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
Correct ![]() Boy |
Bearings at a tenner a go
Very true! I wont say a word more on the subject |
