Home > Wheels & Tyres > BFG "blue"side wall writing |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 |
Use hot water it's a wax 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
26th Sep 2014 7:25pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20340 |
It's not a fault, it will go naturally in a short period of time.
If you really are that desperate to remove it as above a a stiff brush will remove it. |
26th Sep 2014 7:29pm |
GUM97 Member Since: 05 Feb 2012 Location: Cheshire Posts: 3555 |
Don't brush it
Hot soapy water and a bit of elbow grease will shift it An engine to TDi for! "Land Rover- Proudly turning drivers into mechanics since 1948" |
26th Sep 2014 7:36pm |
Jonno1968 Member Since: 24 Oct 2013 Location: Leicestershire Posts: 245 |
Ok.....will rub it gently....
26th Sep 2014 7:38pm |
Gum - I meant like an alloy wheel bush or nylon bristle brush. NOT a wire brush on any account.
26th Sep 2014 7:49pm |
Get it off the tarmac into some proper mud, that'll take the blueness off. It has on mine and got rid of the white that I had fitted on the inside out of the way
26th Sep 2014 8:01pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5692 |
It should not matter as it should be on the inside. So only visible from below the vehicle.
26th Sep 2014 10:16pm |
Then it looks like someone doesn't know what they're doing that fitted them because they are obviously inside out.
26th Sep 2014 10:23pm |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 |
Or worse have 3 in and one out
26th Sep 2014 10:34pm |
.And shake it all about...
26th Sep 2014 10:43pm |
robertcoby Member Since: 26 Aug 2014 Location: lothian Posts: 29 |
Mine's came off with a power washer.
28th Sep 2014 6:37am |
