Home > Wheels & Tyres > BFG "blue"side wall writing
Jonno1968
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Orkney Grey
It seems that the blue tinge to my sidewalls wont dissapear after all. So....is it a fault and should i complain amd secondly if i painted the letters back to white...what sort of paint should i use to last?
Post #360375 26th Sep 2014 7:21pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
Use hot water it's a wax 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #360376 26th Sep 2014 7:25pm
It's not a fault, it will go naturally in a short period of time.
If you really are that desperate to remove it as above a a stiff brush will remove it.
Post #360378 26th Sep 2014 7:29pm
GUM97
Don't brush it Shocked
Hot soapy water and a bit of elbow grease will shift it Thumbs Up An engine to TDi for!
Post #360383 26th Sep 2014 7:36pm
Jonno1968
Ok.....will rub it gently.... Embarassed
Post #360384 26th Sep 2014 7:38pm
Gum - I meant like an alloy wheel bush or nylon bristle brush. NOT a wire brush on any account.
Post #360387 26th Sep 2014 7:49pm
JWL
Get it off the tarmac into some proper mud, that'll take the blueness off. It has on mine and got rid of the white that I had fitted on the inside out of the way Thumbs Up
Post #360390 26th Sep 2014 8:01pm
landy andy
It should not matter as it should be on the inside. So only visible from below the vehicle. Whistle Whistle
Post #360422 26th Sep 2014 10:16pm
Then it looks like someone doesn't know what they're doing that fitted them because they are obviously inside out. Ner Ner Snigger
Post #360423 26th Sep 2014 10:23pm
shaggydog
Or worse have 3 in and one out Whistle
Post #360426 26th Sep 2014 10:34pm
.And shake it all about... Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter
Post #360428 26th Sep 2014 10:43pm
robertcoby
Mine's came off with a power washer.
Post #360660 28th Sep 2014 6:37am
