![]() | Home > Wheels & Tyres > BFG "blue"side wall writing |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
Use hot water it's a wax 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20613 ![]() ![]() |
It's not a fault, it will go naturally in a short period of time.
If you really are that desperate to remove it as above a a stiff brush will remove it. |
Don't brush it
![]() Hot soapy water and a bit of elbow grease will shift it ![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
Jonno1968 Member Since: 24 Oct 2013 Location: Leicestershire Posts: 245 ![]() ![]() ![]() |
Ok.....will rub it gently....
Gum - I meant like an alloy wheel bush or nylon bristle brush. NOT a wire brush on any account.
Get it off the tarmac into some proper mud, that'll take the blueness off. It has on mine and got rid of the white that I had fitted on the inside out of the way
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5804 ![]() ![]() |
It should not matter as it should be on the inside. So only visible from below the vehicle.
Then it looks like someone doesn't know what they're doing that fitted them because they are obviously inside out.
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
Or worse have 3 in and one out
.And shake it all about...
robertcoby Member Since: 26 Aug 2014 Location: lothian Posts: 29 ![]() ![]() |
Mine's came off with a power washer.
