Home > Puma (Tdci) > caterhams LAST problem!
Page 8 of 15 <123 ... 789 ... 131415>
munch90
no
Post #387189 10th Jan 2015 8:26pm
Caterham
GOOD !
I just need to sit back and enjoy it running really really well for as long as it lasts. not only does it seem smoother at the moment but the responsiveness is great, easily able to adjust engine speed to match transmission speed etc when changing down. I'm sure I even noticed a slight kick as the turbo started to do its stuff.
either I've just learn't how to drive again or something is working as it should?
Confused but happy.
Post #387236 10th Jan 2015 10:02pm
Caterham
Munch90 -. Sorry just couldn't resist having a look at the wiring....its too early to say for sure but following the new caliper i'd say the def has run faultlessly.
Photo below to my mind suggests the abs does talk to the ecm. Under what conditions signals are sent and how they are acted on I have no idea but would be interested to know
Post #387471 11th Jan 2015 4:34pm
munch90
yes , what it doesn't tell it that there is a leak !
no way fitting a new caliper can have any effect on your engine
Post #387509 11th Jan 2015 6:43pm
Caterham
I'm grasping at straws here and I fully accept that....to a point Razz
I've felt that there was an issue with the brakes and clutch before relating to the impact they can have on the engine ie the loss of power (guessing similar to that experienced my those who have a blown fuse on the brakes)....
The caliper started leaking a lot recently but I'm not convinced there wasn't some kind of problem with it for a long time before that..... is it possible there was some air in the piston which would expand due to heat - this then getting picked up by the abs?
I really don't know but since the new caliper has been fitted things are good and it just seems to much of a coincidence?
On top of that the following ;
Seemed like I had a problem with front diff for a long time (ok this is mechanical not ecm / abs)
Brakes stuck on three times (seemed electrical / electronic not mechanical)
Intermittent poor engine running with similar characteristics of blown fuse on brake lights?
Will be doing c500 miles this week so should be able to confirm if all is good so following replacement caliper????????????
Post #387529 11th Jan 2015 7:33pm
munch90
If we get one in next week running dodgy , i dont think i will suggest fitting a caliper in front of the other blokes there Laughing Laughing
what was done to brakes when they stuck on then ?
Did they come on while moving ?
after you braked?
Post #387540 11th Jan 2015 8:11pm
CatherineF
Caterham, I have to ask as a newbie on the forum and not fully familiar with your Defender.
Have you had it long?
Has it always been as problematic as it comes across?
Did you buy it with a warranty?
Is it worth cutting your losses and swapping it for another Defender? 2015 Audi Q3 Quattro S Line Plus 184 TDI Stronic
2010 90 SMC Over Land Nero Edition - Santorini Black Metallic (Now Departed)
Post #387544 11th Jan 2015 8:17pm
munch90
^^^ swapping , But he loves it Rolling with laughter
Post #387545 11th Jan 2015 8:20pm
Martin
Site Admin
Oooooh don't go there Laughing  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #387546 11th Jan 2015 8:23pm
CatherineF
Ahh OK.
Is it an early car? 2015 Audi Q3 Quattro S Line Plus 184 TDI Stronic
Post #387547 11th Jan 2015 8:26pm
Caterham
I wouldn't suggest a new caliper either.......but I wouldn't now rule out the brakes altogether either.
Had the def from new (over 4yrs now /50+k miles) and yes it's been a pain in the rear end ever since with various problem but there's been an intermittent problem since day which so many times I thought i'd fixed only for it to return (this could prove to be the same? ).
Munch90 - 3 times the brakes have stuck on...first time from a fresh start....small movement of brake pedal and abs would be kicking in on non tarmac surface (lifted brake pedal up and click all ok), second time and stuck in traffic and brakes seemed to progressively bind on (again messed / lifted brake pedal and click all ok), third time reversing on drive (can't remember what happened to solve) .??
Post #387550 11th Jan 2015 8:32pm
Caterham
Embarassed
Post #387552 11th Jan 2015 8:36pm
jimbob7
Caterham wrote:
GOOD !
Confused but happy.
So your previously (permanently??) seized caliper is no longer seized Rolling Eyes ?? Pov.spec,ftw. 2006, 110,TD5.
Post #387606 12th Jan 2015 12:22am
mk1collector
If you had to lift the brake pedal up and it was fine then I'd suggest it was a pedal problem rather than brake problem.
Post #387609 12th Jan 2015 12:29am
K9F
Please change the thread title:
Something like:
"Caterham's ongoing saga of percepted faults that anyone that has been constantly bombarded with them have either found themselves bored out of their tree, clinging to the abyss or have lost the will to live long ago."
Catherine is a relative newcomer and picked up on it straight away. How many others have suggested you move on to another marque historically? Windscreen rubber.......change that and all your braking issues will be sorted.
+1 Thumbs Up
Happy New Year Wayne.....Obviously not a new leaf! Laughing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #387627 12th Jan 2015 7:38am
