Home > Puma (Tdci) > Rear Recover Point Defender 90
Page 1 of 3 123>
KarlB
Australia 2010 Defender 90 Puma 2.4 XS CSW Rimini Red
I know this has been done to death but I haven't yet seen a satisfactory solution. The OEM tow bar for a Puma D90 reduces the departure angle by more than one third and this seems like a silly option for a rear recovery point for a D90. After all, you buy one, at least in part, for its excellent departure angle. The 'tradional' place to fix JATE rings is reportedly not strong enough as it is no longer strengthened like Defenders in the past, so JATE rings are not a safe option. There must be a solution. I have recently seen a video of D90 at a LR Experience Centre pulling a 12 tonne DAF truck as a demo. I suspect it was using a Dixon Bate fixture of some type but how was it affixed to the D90. Has any one taken any notice of what recover points are used on D90s at the Experince Centres?
KarlB
Canberra Australia
Post #28325 29th Mar 2010 3:16am
alantd
3 options:
Mount to the rear crossmember. Good enough in a straight line pull (NATO jaw mounts to the 4 central holes) but questionable from an angle.
Mount to the chassis. Such as a Jate ring. I know what you mean about the lack of reinforcing but I've never seen or heard of anyone tear their chassis rails with a recovery. If you mount two then you have the option to spread the load further.
Mount to both. Such as aDixon-Bate adjustable or Southdown. Essentially this will give you the strongest possible anchor but by tying to the chassis rails you inevitably compromise departure angle. The D-B setup is even more extreme than the OEM one but you get more height. One that started out as a 2.4 TDCi 110 XS
Post #28330 29th Mar 2010 6:08am
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
I looked at the LRDE video and it looks to me they have a angle iron below the chassis but I cannot see any additional support to the front like when you have a standard tow bar.
That is off course an option make a very short towbar and reuse the additional supports to the chassis.
It help to give some more protection to the tank too. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #28331 29th Mar 2010 6:47am
KarlB
Thanks for replies alantd and roel. But, gee wiz, I expected more replies. What do others on the forum with Puma D90s do about rear recovery?
Post #28537 31st Mar 2010 12:33am
Bosun
2008 Defender 90 Puma 2.4 XS CSW Tonga Green
Be carefull when fitting rear Jate rings, they come very close to the plastic fuel tank. The lashing eyes are also awkward to remove as they have to be sawn off. They are bolted on before the tank is fitted, presumably because of the clearance with the fuel tank (the head of a bolt is thinner than a nut and a few threads of protruding bolt). The Jate rings will need to be threaded one side. Jate rings that use a bolt with a nut won't work! Hope this is usefull.
Post #28549 31st Mar 2010 7:12am
alantd
That's interesting - I never bothered to look on my old 90. The 110 is perfectly accessible.
My OEM and D-B adjustable tow hook (with the chassis ties) mount to the same holes so how does that work on a 90? I can't imagine that fitting the OEM tow hook is a tank-out job Question One that started out as a 2.4 TDCi 110 XS
Post #28558 31st Mar 2010 7:38am
MrFlips
Wales 2008 Defender 90 Puma 2.4 PU Santorini Black
I took the approach of buying a Safari Equipment 2" receiver that bolts onto the rear cross-member, and then sits just underneath it, keeping out of the way, but allowing you to attach a recovery point when needed (or towball when needed). Peter
2008 SWB Truck Cab
1952 80" Soft top
Post #28591 31st Mar 2010 12:03pm
mse
i like these and have one on the disco - remember for towing its not type approved Big Cry but they are very good. Mike
Post #28592 31st Mar 2010 12:07pm
AndrewS
Safari Equip 110 I presume the 90 may be similar Question
 130's have feeling's as well you know Smile
Post #28618 31st Mar 2010 2:49pm
MrFlips
Yep, the 90 version looks just the same Thumbs Up Peter
2008 SWB Truck Cab
1952 80" Soft top
Post #28628 31st Mar 2010 3:50pm
KarlB
Thanks to all who replied now have a bit more to think about.
KarlB
Post #28959 4th Apr 2010 3:39am
jst
LRE hontion we ran std two hitches on 90 and 110s
i run a southdown rear tow pack on my 110, better protection for the tank, no loss of departure angle plus option for a tow hitch or a recovery eye. i moved the electrics up into the rear 'PTO' hole in the chassis Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #29045 5th Apr 2010 3:18pm
discocuzzy
Just ordered the safari equipe one to tow my Sankey...are the recovery recievers the warn 2" ones Thumbs Up You cannot teach stupid people to do clever things
Post #29055 5th Apr 2010 7:38pm
ay4alex
United Kingdom 2008 Defender 110 Puma 2.4 XS DCPU Java Black
they are indeed, any 2" attachment will fit. we've got one from Scorpion racing, everything is the same, apart from the sh*t powdercoating. 110 Tdci Double Cab
Post #29066 5th Apr 2010 8:23pm
alantd
How does it line up? Do you have a plate that comes out of the 2" hole and points up to keep the NATO in line with the holes in the crossmember? Will that be strong enough (there are folks who have bent their crossmember towing a Sankey). If your NATO is in line with the 2" bracket (the strongest position) won't it be too low?
I have to admit, though - not having a plough on the back is quite appealing. One that started out as a 2.4 TDCi 110 XS
Post #29079 5th Apr 2010 9:22pm
Page 1 of 3 123>
