Home > Maintenance & Modifications > Roof Mounted Spots
Page 1 of 4 1234>
MuddyMarky
United Kingdom 2011 Defender 110 Puma 2.4 DCPU Stornoway Grey
Roof Mounted Spots
I'm trying to find some suitable spots to go on the front of my roofrack. I'd ideally like some smallish (more discreet - guessing approx 100-120mm across), oval/rectangular spots, not chrome, but am having trouble finding anything I like the look of, let alone being able to actually see if they'd be OK for mounting up there, etc....
Any ideas/tips for what I should look out for, etc, etc Question
Ta! Thumbs Up
*edited for dreadful spelling! Wink Mark
2011 110 XS DC
Stornoway Grey
Post #26927 15th Mar 2010 7:25pm
The Boy
Hella's new range of curved ones are quite nice. I'll see if I can find a link.
FF series http://b2c.hella.com/b2c_hella/b2c/init.do...m=hella_gb
Post #26929 15th Mar 2010 7:49pm
discocuzzy
Mark,
Ive got Roo 140s, very pleased with the light they kick out.....even though they are not wired up yet on this puma Embarassed You cannot teach stupid people to do clever things
Post #26930 15th Mar 2010 7:54pm
Come on hurry up
Post #26936 15th Mar 2010 8:16pm
MuddyMarky
Been doing a lot of looking around, and think these look good....what do we think?:
http://www.autostylinguk.co.uk/hella-light...ff50-1683/
What's everyone's opinion, a pair of them, or a set of 4 for the front of my roof rack.....thinking they should come on with high beam, too.....what do you reckon? Twisted Evil Mark
2011 110 XS DC
Stornoway Grey
Post #26957 15th Mar 2010 10:16pm
Laurie
They're illegal for use on a public road.
Officially it's not allowed to be able to switch them from the driver's seat.
Post #26962 15th Mar 2010 11:10pm
K9F
Obviously they need to be isolated for public road use and switched on independantly off-road when/if needed. Would suggest you have a look at this switch that I sourced for my Lightforces....
The driving light switch is part no YUG 000540LNF and can be purchased from www.britishparts.co.uk or your local dealers. The switch cover depicts a little lamp with a number 2 in it (not poo by the way) Laughing and fits in to a standard dashboard switch position so there's no need for butchery to fit it! The switch is also illuminated and has a red led in it that illuminates when the system it is supplying is swtched on! Hope this helps.
Dog Thumbs Up Dog If you go through life with your head in the sand....all people will see is an ar5e!!
Post #26969 16th Mar 2010 7:43am
MuddyMarky
Cheers Malc, I've already used that 'no 2' switch to operate my rear mounted worklight, as I wanted to be able to use it regularly, for additional reverse light, as well as a worklight, so wanted it accessible and factory looking.....unless there's a switch with a 'no 3' on it Question
The isolator switch I use for my existing spots is discreetly fitted elsewhere. Was thinking I would mount a second switch next to this for the roof mounted lights, so they could also be isolated.
Cool Mark
2011 110 XS DC
Stornoway Grey
Post #26976 16th Mar 2010 8:50am
MuddyMarky
......also, whats the general feeling....a pair of spots, one fitted at each of the end mountings on my roof rack, or a set of 4, one for each of the mountings up there? Think I'm edging towards just 2 of them to start with, one at each side....if i switch/fuse/cable it corrrectly, I can always add a second pair later if I want to.... Thumbs Up Mark
2011 110 XS DC
Stornoway Grey
Post #26977 16th Mar 2010 8:54am
The Boy
Yes but make sure you use the correct amp rated wire/cable.
eg:
2 x 55 watt = 110 div by 12 volt = a minimum of 9.17 amp rated wire.
4 x 55 watt = 220 div by 12 volt = a minimum of 18.34 amp rated wire.
I had four on the roof rack and used two looms with 17.5 amp rated wire. This was so if I wanted I could uprate the bulbs to 100w.
Post #26978 16th Mar 2010 9:05am
K9F
4
Plain & Simple
44444444444
Rolling with laughter If you go through life with your head in the sand....all people will see is an ar5e!!
Post #26980 16th Mar 2010 9:14am
mse
Its actually NOT illegal to use driving lights at any height on the front of the vehcile on the main beam circuit.
The main beam circuit has the required warning light to show they are on and switched not to dazzel.
FOG lights cannot be used any higher than the bumper - these are the only lights that carry this legal height and position stipulation.
So you are free to fit and use driving lights on the roof! (which as to be good Thumbs Up ) Mike
Post #27117 17th Mar 2010 1:02am
MuddyMarky
Nice one- they're the driving light version that I'm looking at anyway
Thumbs Up
Anyone on here have any exp/pics of a defender with roof spots, but (being fussy) - the Hella ff50's?
Smile
By any chance Question
*edited because of big sausage fingers struggling to type on my iPhone! Lol Mark
2011 110 XS DC
Stornoway Grey
Post #27181 17th Mar 2010 9:49am
mhill
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Bonatti Grey
http://www.x-eng.co.uk/X-Lite.asp
these look good........
Post #27295 17th Mar 2010 11:39pm
Laurie
Don't they have to be mounted at the front of the vehicle to be legal?
Post #27298 18th Mar 2010 1:47am
Page 1 of 4 1234>
