![]() | Home > Maintenance & Modifications > Roof Mounted Spots |
Hella's new range of curved ones are quite nice. I'll see if I can find a link.
FF series http://b2c.hella.com/b2c_hella/b2c/init.do...m=hella_gb |
discocuzzy Member Since: 16 Jul 2008 Location: surrey Posts: 1200 ![]() ![]() |
Mark,
Ive got Roo 140s, very pleased with the light they kick out.....even though they are not wired up yet on this puma ![]() |
Come on hurry up
MuddyMarky Member Since: 01 Feb 2010 Location: Oxfordshire Posts: 548 ![]() ![]() ![]() |
Been doing a lot of looking around, and think these look good....what do we think?:
http://www.autostylinguk.co.uk/hella-light...ff50-1683/ What's everyone's opinion, a pair of them, or a set of 4 for the front of my roof rack.....thinking they should come on with high beam, too.....what do you reckon? ![]() 2011 110 XS DC Stornoway Grey |
They're illegal for use on a public road. Officially it's not allowed to be able to switch them from the driver's seat. |
Obviously they need to be isolated for public road use and switched on independantly off-road when/if needed. Would suggest you have a look at this switch that I sourced for my Lightforces.... The driving light switch is part no YUG 000540LNF and can be purchased from www.britishparts.co.uk or your local dealers. The switch cover depicts a little lamp with a number 2 in it (not poo by the way) ![]() ![]() ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
Cheers Malc, I've already used that 'no 2' switch to operate my rear mounted worklight, as I wanted to be able to use it regularly, for additional reverse light, as well as a worklight, so wanted it accessible and factory looking.....unless there's a switch with a 'no 3' on it
![]() The isolator switch I use for my existing spots is discreetly fitted elsewhere. Was thinking I would mount a second switch next to this for the roof mounted lights, so they could also be isolated. ![]() 2011 110 XS DC Stornoway Grey |
......also, whats the general feeling....a pair of spots, one fitted at each of the end mountings on my roof rack, or a set of 4, one for each of the mountings up there? Think I'm edging towards just 2 of them to start with, one at each side....if i switch/fuse/cable it corrrectly, I can always add a second pair later if I want to....
Yes but make sure you use the correct amp rated wire/cable.
eg: 2 x 55 watt = 110 div by 12 volt = a minimum of 9.17 amp rated wire. 4 x 55 watt = 220 div by 12 volt = a minimum of 18.34 amp rated wire. I had four on the roof rack and used two looms with 17.5 amp rated wire. This was so if I wanted I could uprate the bulbs to 100w. |
4
Plain & Simple 44444444444 ![]() Treat every day as if it is your last....one day you will be right!! |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5070 ![]() ![]() ![]() |
Its actually NOT illegal to use driving lights at any height on the front of the vehcile on the main beam circuit. The main beam circuit has the required warning light to show they are on and switched not to dazzel. FOG lights cannot be used any higher than the bumper - these are the only lights that carry this legal height and position stipulation. So you are free to fit and use driving lights on the roof! (which as to be good ![]() |
Nice one- they're the driving light version that I'm looking at anyway
![]() Anyone on here have any exp/pics of a defender with roof spots, but (being fussy) - the Hella ff50's? ![]() By any chance ![]() *edited because of big sausage fingers struggling to type on my iPhone! Lol Mark 2011 110 XS DC Stornoway Grey |
mhill Member Since: 24 Jan 2010 Location: Tendring, Essex Posts: 46 ![]() ![]() ![]() |
http://www.x-eng.co.uk/X-Lite.asp
these look good........ |
Don't they have to be mounted at the front of the vehicle to be legal? |
