Home > Maintenance & Modifications > Roof Mounted Spots
Page 2 of 4 <1234>
MuddyMarky
United Kingdom 2011 Defender 110 Puma 2.4 DCPU Stornoway Grey
Laurie wrote:
mse wrote:
Laurie wrote:
MuddyMarky wrote:
thinking they should come on with high beam, too.....what do you reckon? Twisted Evil
They're illegal for use on a public road.
Officially it's not allowed to be able to switch them from the driver's seat.
Its actually NOT illegal to use driving lights at any height on the front of the vehcile on the main beam circuit.
The main beam circuit has the required warning light to show they are on and switched not to dazzel.
FOG lights cannot be used any higher than the bumper - these are the only lights that carry this legal height and position stipulation.
So you are free to fit and use driving lights on the roof! (which as to be good Thumbs Up )
Don't they have to be mounted at the front of the vehicle to be legal?
No idea....i'll fit them anyway, and try not to blind any on-coming coppers!! Rolling with laughter Mark
2011 110 XS DC
Stornoway Grey
Post #27395 18th Mar 2010 7:29pm
PaulMc
Fog Lights can be fitted higher than the regulations allow for, but they then become "Driving Lights" and must conform to the Driving Light regulations, i.e. only on with main beam.
Most people with roof lights use a pair of fog lamps on the outer mounts to give a close wide spread of light and a pair of driving or spot lamps on the middle mounts to give some distance -
FF50 Fog
FF50 Driving
MuddyMarky wrote:
Anyone on here have any exp/pics of a defender with roof spots, but (being fussy) - the Hella ff50's?
My mate has fitted Hella FF50's on a roof bar to his Range Rover, he's used a pair of fog lamps and a pair of driving lamps -
To mount the lamps below the mounting tabs, he had to use a longer mounting bolt with a spacer tube, because the lamp's body fouled the roof bar.
Paul.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Paul.
Post #27566 20th Mar 2010 9:37pm
MuddyMarky
Thumbs Up
Quality....nice one Paul, thanks. Good pic, too. Certainly think they're the ones I'll be going for - personally think they look the best I've seen so far. Shouldn't be a problem fitting them as they'll be going on top of my mounting points on my roof rack (don't think there's room under, anyway!).
Good idea about the 2 outsides being fogs, 2 middle ones being spots. Still have all 4 come on with main beam though, I'm assuming? - Think I'd keep it that way, would certainly give a great spread of light, esp with my Wipacs on the A-bar too!
Do you know if he has much problem with the Hella's (fogs, especially) lighting up his bonnet when they're in use? Mark
2011 110 XS DC
Stornoway Grey
Post #27622 21st Mar 2010 6:33pm
PaulMc
They can be mounted upright or pendant - so no problems there.
Yes - all 4 come on together with main beam, but with a switch in the feed from the main beam so that they don't have to come on with main beam (MOT time, etc...)
They do light up the bonnet, but on his Range Rover it's not given him too much of a problem, as it's Dark (Ardennes) Green.
He was thinking of making some shields to go under the lamps, but hasn't got around to it yet Rolling Eyes
If you did want to make some shields to fit under the lamps, it should be fairly easy to fit them, as the lamps mount with a 'stirrup' bracket that fixes to them at their sides - these mounting points could also be used to fix a shield to.
Paul. Paul.
Post #27675 22nd Mar 2010 12:00am
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
I'm fitting a rack with spots, whats the best route for the wiring to get inside the cab?
Post #27798 23rd Mar 2010 8:46am
eutek
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Following this thread for some time... just want to make sure that I understand - it is legal to use driving lights on the road, at any height, but not fog lamps? I could motor with driving lights bolted to the front of my roof rack and not fall afoul of the law?
Post #27825 23rd Mar 2010 1:06pm
heinrichnel
Namibia 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Mounting light on the roof
Hi guys, first post on this site.
Question? I purchased 4 IPF 868 lights and will mount them on a mm4x4 light bar. The question is how do I get the wiring from the roof to inside of the 110 without having any visible wires running down the side?
Thanks
Heinrich
Post #29722 13th Apr 2010 2:57pm
K9F
Re: Mounting light on the roof
heinrichnel wrote:
Hi guys, first post on this site. The question is how do I get the wiring from the roof to inside of the 110 without having any visible wires running down the side? Thanks Heinrich
Welcome Heinrichnel,
I do not have roof lights but have heard of people running the cables down a snorkel if you've got one fitted! If you haven't got one fitted here's the excuse you need to go buy one! 'Fekete' another forum member will be able to advise in greater detail...send him a 'pm' or he may be along shortly!
Thumbs Up Dog If you go through life with your head in the sand....all people will see is an ar5e!!
Post #29724 13th Apr 2010 3:16pm
heinrichnel
Good idee, I have a Mantac snorkel fitted, will check it out.
Post #29728 13th Apr 2010 3:53pm
Cibit
Our TD5 has the wiring fed through a drill hole through the roof top. Will go take a snap. hang on Thumbs Up
Here you go
Land rover did this AFAIK Whistle 59 2.4 110 XS Utility
55 TD5 110 CSW Special Vehicle
Post #29730 13th Apr 2010 3:59pm
ay4alex
United Kingdom 2008 Defender 110 Puma 2.4 XS DCPU Java Black
Here you go
Shocked Shocked Shocked Shocked Shocked Shocked
Glad LR did that and not me! there's already enough holes in mine! Laughing 110 Tdci Double Cab
Post #29733 13th Apr 2010 4:36pm
heinrichnel
Thanks guys, love this forum, I belong to another couple but never the same amount of responses!
Cibit, do you think something like a Hella plug would work instead of just drilling a hole in the roof? Or any other type of plug that could be used?
Post #29734 13th Apr 2010 4:42pm
Cibit
This weekend I was looking over a modified disco 1. He had a cut off switch through a wing and it looked a really good job. I am sure a plug would be the best option much easier to waterproof it. The silicone around the wires look amatuerish really. I would change it but it would mean headlining removal Razz . Will leave it till it leaks Thumbs Up 59 2.4 110 XS Utility
Post #29735 13th Apr 2010 4:58pm
discocuzzy
Put a quick connector in that you can disconect at the rack and chase the wires down the snorkel, into the wing then up into the battery box Thumbs Up
From the battery box, come out up the bulkhead and in through the grommet behind the dash to your switches Thumbs Up You cannot teach stupid people to do clever things
Post #29743 13th Apr 2010 7:01pm
fekete
Same as Discocuzzy... but save drilling holes through the wing just go down the snorkel and under the bonnet and then through the bulk head Thumbs Up oh welcome 2 the site as well NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #29752 13th Apr 2010 8:18pm
Page 2 of 4 <1234>
