Home > In Car Electronics > gps for ipad
Page 3 of 3 <123
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
Done!
Post #319645 27th Mar 2014 10:29pm
Blacktt600
England 2008 Defender 110 Puma 2.4 XS CSW Cairns Blue
Border terrier- that's great thanks! You found the codes before I had time to respond to the other post! Very Happy
Post #319646 27th Mar 2014 10:31pm
landy andy
Post #319648 27th Mar 2014 10:35pm
Blacktt600
Hi Andy- I was looking at your post last night, it looks spot on. Just struggling with the size of iPad mini with case, it's just slightly too big for the ram mounts for the mini. They seem to cater for sleeve but not a rubber case.
Martin
Post #319652 27th Mar 2014 10:41pm
Blacktt600
Rob - photo of mine so you can keep your eye out for me.
Post #319658 27th Mar 2014 11:02pm
landy andy
Martin
Any good.
http://www.tallonsystems.com/products/view...et_holder/
Andy
Post #319661 27th Mar 2014 11:13pm
Blacktt600
Like the look of that link but again it doesn't give max dimensions. iPad mini with case on is 6" wide.
Post #319707 28th Mar 2014 8:18am
landy andy
It works with a 7" even in a case, and the Product size (mm) :
85x180x95
So thought it would do the job. You could ask Alistair at Tallon the question Thumbs Up
Andy
Post #319709 28th Mar 2014 8:22am
Blacktt600
May have to do that. The size 85x180x95 doesn't make any sense, iPad with case is 215 x 150.
Martin
Post #319711 28th Mar 2014 8:27am
landy andy
Here you go
The RAM X-Grip II™ has a clean and clever four leg design that sports great holding power without hiding your tablet behind foam pads and plastic. The perfect compliment to the modern sleek design of tablets, the RAM X-Grip II™ is the tablet holder evolved. Compatible and interchangeable with a wide range of popular RAM Mounting products, this elegant universal holder is ready to compliment your tablet.
The RAM-HOL-UN8B consists of a spring loaded holder and 1" rubber ball connected to the back. Easy access grip knobs are located on the back of the holder for quick release of your tablet. The RAM-HOL-UN8B expands and contracts for perfect fit of most 7" tablets.
Compatible Devices:
Apple iPad mini
Amazon Kindle
Amazon Kindle Fire
Amazon Kindle Fire HD
Archos 7
Asus EEE Pad Memo
Barnes & Noble NOOKcolor
BlackBerry PlayBook
Dell Streak 7
HTC Flyer
Panasonic Toughpad™ JT-B1
Samsung Galaxy Note 8.0
Samsung Galaxy Tab (7" version)
Samsung Galaxy Tab 7.0 Plus
Samsung Galaxy Tab 2 7.0
All devices that maintain the following dimensions below
Holder Dimensions:
Minimum Width = 57.15mm
(Devices 57.15mm in width must be a minimum of 177.8mm in height to fit)
Maximum Width = 146.05mm
Depth = 22.22mm
Features:
1. Spring loaded holder expands and contracts for perfect fit of your tablet
2. Rubber coated tips will hold your tablet firmly
3. Versatility of holder allows for attachment to many RAM-to-RAM ball and 1" socket mounts
4. Socket technology allows for multiple adjustment angles and articulation of your tablet
5. Easy access grip knobs, located on the back of the holder for quick release of your tablet
Material:
High Strength Composite with Rubber Tips
Ball Size:
1" Rubber Ball "B" Size
Post #319712 28th Mar 2014 8:27am
Blacktt600
That's the one I was looking at but it's max width is 146.5mm, mine is 150 with the case on.
Not sure if a bigger one would adjust small enough.
Martin
Post #319762 28th Mar 2014 11:48am
landy andy
Next one up is too big. 158.75mm. Min.
Andy
Post #319765 28th Mar 2014 12:02pm
Blacktt600
Wonder how accurate the 146.05mm is, no doubt ram been ram it will be spot on.
Cheers for the help on this.
Martin
Post #319768 28th Mar 2014 12:08pm
Ken B
RAM all the way for me... I have one for an iPad Mini and it is a great setup with Memory Map and TomTom for offroad and onroad navigation Thumbs Up Defender 90 TD5 County -
You need only two tools in life: WD-40 and duct tape.
If it doesnt move and it should: WD-40.
If it moves and shouldnt: duct tape it.
Post #321995 6th Apr 2014 6:45pm
Page 3 of 3 <123
